Where can i buy a the fuel line can't get at autozone?
Old Oct 13, 2010 | 09:06 PM
92Yotaa's Avatar
ok i made a dumb mistake when i pulled my 22re out of my pickup the other day i though i had everything unhooked and i began lifting my fuel line snapped now i cant find a place that has then autozone doesnt sell then?? any info?
Old Oct 13, 2010 | 09:09 PM
dropzone's Avatar
Fossilized
napa, o'reilly's, schucks.....dealer...central farm and ranch....google.
Old Oct 13, 2010 | 09:28 PM
scope103's Avatar
My autozone carries straight sections of fuel line with the fittings already on each end. Measure the piece you broke, and buy the closest length. You'll need a tubing bender, but having the fittings pre-fitted helps a lot. Making the double-taper fitting you need from raw tubing is not easy.
Old Oct 14, 2010 | 02:25 AM
swaysidelife's Avatar
Exactly.. The Autozone I work at has it from 6 inch sections to 25ft rolls with
every fitting size and pitch under the moon.
If Autozone cant get it go to Napa like said above they can get certain thing
that other auto part stores cant dream of LOL
Old Oct 14, 2010 | 06:19 AM
clocklaw's Avatar
Been there done that on my 3VZ-E......had to get it at the dealer.
Old Oct 19, 2010 | 03:15 PM
92Yotaa's Avatar
ok it is the fuel pressure regulator hose that busted
Old Jan 29, 2011 | 11:03 AM
Challenga's Avatar
Are you talking about the little rubber hoses off of the fuel pressure regulator? If so, they sell that at autozone as efi fuel hose. If you are talking about the hard lines that attach to your regulator you need to go to the dealer.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Jonny246
Jul 12, 2015 04:51 AM
