Wheel Bearings
Old Nov 29, 2015 | 10:27 AM
Matt McLellan's Avatar
Wheel Bearings
I have a 91 Pickup 22-RE with RWD. The front left wheel needs a new bearing and I know how to do it, but I would like some instructions. Does anyone have any websites that are good for this? I have searched but can't find anything good. Thanks everyone!
Old Nov 29, 2015 | 01:42 PM
wyoming9's Avatar
Red face
Are you planning to do both sides ??
This is a 2wd truck ??
Pretty simple .
remove the wheel
remove the caliper bracket with caliper
Remove the bearing retainer nut the lock and the preload adjustment nut
Pull the rotor off
remove the seal
remove inner bearing
clean out the rotor clean off the spindle
Pack your new bearings
Put your new races in being careful to get them seated straight.
install the inner bearing
install the new seal
put it all back together .
With me now is the time I see that I lost one of the brake pads
The only real difference if you have a 4x4 is the 52mm spindle nut socket
Old Nov 29, 2015 | 01:43 PM
No, I just wanted to do the front left, and yes, it is a 2wd car.
Old Nov 29, 2015 | 02:06 PM
k-ray's Avatar
Standard rule of thumb : What you do to one side is also done to the other side. You will never have to wonder how much life is left in the 'not done' side. And if one side is toast, the other side isn't far behind.
My .02.
Old Nov 29, 2015 | 02:54 PM
ToyoToler's Avatar
This ^^^
Old Nov 29, 2015 | 05:57 PM
muddpigg's Avatar
My .02.
Solid advice!!
☆OMI☆
Nov 23, 2015 09:02 PM
82YoTuh
Nov 7, 2015 12:30 AM
Joa
10
Nov 5, 2015 10:53 PM
Jwsaul
Nov 4, 2015 03:49 PM
Lobster70
Nov 4, 2015 09:14 AM
