What transmission do I have? solenoids?
Old Oct 24, 2009 | 09:18 AM
benstruck's Avatar
Hello,
I have a 1991 4runner V6 4wd auto, i ordered some solenoids for the transmission but they do not appear to be the same ones on my vehicle. They mount the same but electrical connection is oriented in diff direction and they are smaller. How can I confirm which transmission I have and which solenoids I need?
Thanks for help
Old Oct 24, 2009 | 04:28 PM
benstruck's Avatar
anyone?
Old Oct 24, 2009 | 04:37 PM
Shawn6string's Avatar
Tag on the fire wall should tell you. At the bottom of it shoul be ...paint code/trimcode/gear code/tranny code. I bet it is a (a340?) f or h... Cant remember
Old Oct 24, 2009 | 04:47 PM
https://www.yotatech.com/wiki/index.php/Main_Page
...check out the wiki page...lots of info
i looked it up ,its a a340h..
Here a few sites for the right solenoids..or do a search on a340h solenoids and see what you come up with.
http://www.bulkpart.com/Merchant2/me...e=A340solenoid
http://www.makcotransmissionparts.com/A340.html
https://www.wittrans.com/showfilter....49&Section=128
Old Oct 24, 2009 | 05:30 PM
buckz6319's Avatar
these are the solenoids I took out of a donor A340H,,,,,take a look and see if they look like the ones you received?...the black one came from the hydraulic transfer case that I tore down last summer
A340H all torn down even the hydraulic transfer case
Old Oct 25, 2009 | 08:30 AM
benstruck's Avatar
Thanks guys, yes those are definitely the same as the solenoids in mine. I was curious because the replacement ones have a ground wire and different electrical connection, but I assume that wouldnt affect anything.
I ordered the ones for A340E and they appear to be slightly different, does anyone know if these will work? these are the ones i had ordered:
http://www.transmissionpartsusa.com/...-00094393a.htm
Old Oct 25, 2009 | 09:33 AM
bugs1961's Avatar
This site gives you the correct Toyota part number for any part on the truck: http://www.toyodiy.com/parts/ Put in your VIN and only parts for your particular engine/transmission combination will show.
Old Oct 25, 2009 | 11:17 AM
buckz6319's Avatar
I can't answer that question.....but if you need the solenoids I have in the picture make me an offer.....good luck!
Old Oct 26, 2009 | 05:59 AM
benstruck's Avatar
The ones I had ordered worked perfectly!! tho they looked nothing alike, thanks for the help guys!! Its driving perfect now!!
pickle6415
Oct 19, 2015 08:08 AM
ToyotaMD
Sep 22, 2015 06:28 AM
briholt
Sep 20, 2015 10:26 PM
TransAmBandit
Sep 20, 2015 06:08 PM
kelly1450
Sep 2, 2015 12:29 PM
