What plug where
Old Mar 10, 2010 | 08:20 PM
melicha8's Avatar
Cool What plug where
It's time again for name that plug! I'm re doing my headgasket and have it all together. While I was in there doing everything I found this little guy down below the battery tray but it is neither of the washer fluid plugs. Can anyone help me out and tell me where it's supposed to connect to and what its function is. It has been jumped with a little wire since I bought it.
Old Mar 11, 2010 | 12:26 PM
melicha8's Avatar
any help?
Old Mar 11, 2010 | 12:28 PM
92 TOY's Avatar
Hey...I'll try to help you BUT...I'm going to assume it's a 22re but that's only because you don't say what engine or what year....need more details.
Old Mar 11, 2010 | 12:34 PM
melicha8's Avatar
Yeah sorry it's a 95 4wd with a 22RE
Old Mar 11, 2010 | 12:44 PM
92 TOY's Avatar
resembles what is plugged into my washer pump.
92 TOY's Avatar
wow, crap, that's blurry big like that
Old Mar 11, 2010 | 12:48 PM
melicha8's Avatar
I definitely checked those. Since it's a 4Runner it has two one front and one for the back but it's baffling since both are already plugged it. It looks like a non OEM radiator could it be some coolant temperature sensor that used to be on the radiator?
Old Mar 11, 2010 | 12:51 PM
92 TOY's Avatar
sorry couldn't help you more than that.
95 and my 92 should be the same i would think....no such other plug around there that I see.
what do you mean, "it was jumped" ??
Old Mar 11, 2010 | 01:09 PM
melicha8's Avatar
It was a female connector and it had a wire inserted on one side bending over and going into the other just as one would do when checking diagnostic trouble codes
Old Mar 12, 2010 | 08:53 AM
melicha8's Avatar
Can anybody take a look in their 4runner and see where this leads?
Old Mar 12, 2010 | 09:19 AM
BlackNite3's Avatar
Looks like it's close enough to the A/C parts that it could be related to that. I know I've "tested" my compressor on other cars by jumping the connector for the A/C pressure switch (turns off the system when too much freon leaks out). Maybe this could have been done by the previous owner and just never hooked back up. Does your A/C work? Is there are switch port in the A/C line nearby? I guess it is usually near the receiver/dryer.
80Truck
Oct 12, 2025 07:25 PM
Blamalam
Mar 12, 2022 07:34 AM
old87yota
Oct 25, 2015 02:15 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
