What flamethrower injectors are better?
Old Jul 2, 2014 | 05:46 PM
cpljenkins01's Avatar
I am about to get a set of flamethrower injectors for my 3vze. I already have a cold air intake and the 7mge afm on it which i love..... I don't know what injectors will work better and what is the difference between the two?
Attached Thumbnails What flamethrower injectors are better?-image-4111034156.jpg   What flamethrower injectors are better?-image-1992817072.jpg
Old Jul 2, 2014 | 05:52 PM
rworegon's Avatar
From a thread of Flame Thrower's: If you have any questions, send a PM or call us at customer service at 888-621-0794.
His PM link:
https://www.yotatech.com/private.php?do=newpm&u=114779
Old Jul 2, 2014 | 06:14 PM
Ok thanks I will call them. Does anyone have any experience with both of them? Woundering what effects each of them have on people's vehicles
Old Jul 3, 2014 | 05:52 AM
Gevo's Avatar
Ask flamethrower about the flow rates of each. Decide if you want MORE fuel and want to adjust parts of your electronics to accommodate, or you want something the car's engine can handle on it's own.
Old Jul 3, 2014 | 06:13 AM
Either or as far as flow rate. I would have to adjust my afm either way I go.
Old Jul 3, 2014 | 06:17 AM
Gevo's Avatar
Not entirely true. The ECU will adjust to a certain percentage of flow differential from stock.
I put the tan ones in my 3vze, and I don't need an adjustment to the AFM.
Old Jul 3, 2014 | 07:01 AM
O ok I have a fuel air ratio gauge in my truck so I will be able to see what kind of reading I will get I would rather have the bigger metal ones
Old Jul 3, 2014 | 08:34 AM
Flame Thrower's Avatar
FormerVendor
the gray (Bosch type 2) injectors flow somewhere around 8% more than stock. this has given a few people problems in the past.
the tan/yellow injectors flow within 2% of stock so there should be no problems or adjustments to be made. and the tan injectors are a later design (Bosch type 3) that is more consistent injector-to-injector and they are less prone to injector deposits.
i recommend the tan injectors. i have them at a low price at the moment because i am still rolling them out and i am still working on the videos i will have for them.
Old Jul 3, 2014 | 09:05 AM
Thehollywood811's Avatar
I also purchased the tan/yellow ones and pretty happy with them
Old Jul 3, 2014 | 10:12 AM
Ok thank you. i will be buying the tan ones then.
Old Jul 3, 2014 | 10:21 AM
Not trying to change the point of this post but how do you like the 7mge afm? I went to go get one from the wreaking yard that they said they'd save for me the day before and they sold it! Can't wait to do the mod
Old Jul 3, 2014 | 10:27 AM
Love it. You have to adjust the fuel ratio back a little but other than that I get better mpg and hp
Old Jul 3, 2014 | 10:31 AM
This is my engine compartment with cold air and 7mge afm
Old Jul 3, 2014 | 10:33 AM
Old Jul 3, 2014 | 10:34 AM
I also did the egr and pair valve del on it and took some hard pipe out that I didn't need after.
Old Jul 3, 2014 | 10:44 AM
Wow that thing looks clean!! I have a cold air intake, flamethrowers, and egr delete also. Can't wait to get my supra afm and coil.. did you do the same to block off the pair as the egr?
Old Jul 3, 2014 | 10:51 AM
I welded the holes on the mounting plates closed on mine
And where'd you get the trick vacuum hoses 😂
Old Jul 3, 2014 | 12:38 PM
Robert m's Avatar
Whats the supra coil going to do that yours isn't now?
Old Jul 3, 2014 | 12:49 PM
If you use a 7mge coil and gap your plugs to supra spec (.042) supposedly it helps performance to go along with the supra afm
