what code?..
Old Dec 21, 2012 | 08:49 AM
JTonJuice's Avatar
what code?..
[YOUTUBE]1OZIH4Pe4Ds[/YOUTUBE]
Old Dec 21, 2012 | 09:01 AM
ksti's Avatar
Originally Posted by JTonJuice
[YOUTUBE]http://www.youtube.com/watch?feature=player_detailpage&v=1OZIH4Pe4Ds[/YOUTUBE]
This link doesn't work
Old Dec 21, 2012 | 10:24 AM
Marc's Avatar
I get 12, 13, 14 and 41.
Old Dec 21, 2012 | 10:25 AM
MudHippy's Avatar
4 codes total.
12, 13, 14, and 41
EDIT: Beat me to it. Oh well...second opinion then.
Old Dec 21, 2012 | 10:30 AM
Dirt Driver's Avatar
Yes it does, but it was tagged incorrectly. All you have to do is copy the url into the address bar or select it in Firefox and right-click one of the "open link in new ___" options.
In the future, put only the video's alphanumeric code, 1OZIH4Pe4Ds, between the [youtûbe][/youtube] tags or just paste the whole URL into the message body and it will open in a new window.
[youtube]1OZIH4Pe4Ds[/youtube]
http://www.youtube.com/watch?feature...&v=1OZIH4Pe4Ds
From that, I got codes 12, 13, 14, and 41 as well.
Old Dec 21, 2012 | 11:59 AM
ksti's Avatar
Thanks for the heads up, but I'm kinda of the Village Idiot when it comes to links and url's and that stuff.
Old Dec 21, 2012 | 01:44 PM
JTonJuice's Avatar
thanks so much guys happy holidays.!!
any ideas how to fix this replace ecm or whole igniter assembly
Old Dec 23, 2012 | 01:19 AM
JTonJuice's Avatar
had stalling problem truck would run only cold for 30 seconds and it would die..replaced ecu to fix problem, tried swapping the maf,efi relay, COR relay, igniter..
Old Dec 23, 2012 | 08:01 AM
scope103's Avatar
Where did you get all those parts? And what do they have to do with codes you're getting?
12, 13, and 14 all have to do with the distributor (NE is generated by the distributor. IGF is generated by the igniter from IGT from the ECM which is triggered by NE). So I'd look at the distributor for that group.
Code 41 is the TPS. There's a (relatively) simple diagnostic for that, and it's probably an adjustment issue (no new parts needed).
Good luck!
Old Dec 23, 2012 | 07:32 PM
JTonJuice's Avatar
Good luck!
hey i research what could cause the stalling problem..i had to tps unplug.. i swap parts off my pops truck..i had a ecu off a parts truck which was a 4x4.. now im running a 4x4 ecu on a 2wd had 3 extra wires knock, and 2 ADD..truck runs great now. I bought this truck from a use car lot for cheap because the couldnt figure out the problem
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
