what code?..
[YOUTUBE]1OZIH4Pe4Ds[/YOUTUBE]
Originally Posted by JTonJuice
(Post 52016305)
[YOUTUBE]http://www.youtube.com/watch?feature=player_detailpage&v=1OZIH4Pe4Ds[/YOUTUBE]
This link doesn't work |
I get 12, 13, 14 and 41.
4 codes total.
12, 13, 14, and 41 EDIT: Beat me to it. Oh well...second opinion then. |
Yes it does, but it was tagged incorrectly. All you have to do is copy the url into the address bar or select it in Firefox and right-click one of the "open link in new ___" options.
In the future, put only the video's alphanumeric code, 1OZIH4Pe4Ds, between the [youtûbe][/youtube] tags or just paste the whole URL into the message body and it will open in a new window. [youtube]1OZIH4Pe4Ds[/youtube] http://www.youtube.com/watch?feature...&v=1OZIH4Pe4Ds From that, I got codes 12, 13, 14, and 41 as well. |
Originally Posted by Dirt Driver
(Post 52016340)
In the future, put only the video's alphanumeric code, 1OZIH4Pe4Ds, between the [youtûbe][/youtube] tags or just paste the whole URL into the message body and it will open in a new window. http://www.youtube.com/watch?feature...&v=1OZIH4Pe4Ds From that, I got codes 12, 13, 14, and 41 as well. |
thanks so much guys happy holidays.!!
any ideas how to fix this replace ecm or whole igniter assembly |
had stalling problem truck would run only cold for 30 seconds and it would die..replaced ecu to fix problem, tried swapping the maf,efi relay, COR relay, igniter..
(Post 52016928)
12, 13, and 14 all have to do with the distributor (NE is generated by the distributor. IGF is generated by the igniter from IGT from the ECM which is triggered by NE). So I'd look at the distributor for that group. Code 41 is the TPS. There's a (relatively) simple diagnostic for that, and it's probably an adjustment issue (no new parts needed). Good luck! |
Originally Posted by scope103
(Post 52016984)
Where did you get all those parts? And what do they have to do with codes you're getting?
