Went wheelin'... now the truck won't start
Old Sep 4, 2007 | 07:44 AM
nix4x4's Avatar
So, yesterday, after I got done havin some fun in the woods with my buddies, my truck wouldn't start. Kinda messing around with the positive battery cable will get it to start. I'm fairly sure its something electrical, any ideas? My first thoughts were that it was a bad ground or connection somewhere. Any help is greatly appreciated
Old Sep 4, 2007 | 07:48 AM
rdlsz24's Avatar
I would guess that as well. While you were wheeling you probably jarred something loose. Have you already checked them?
Rob
Old Sep 4, 2007 | 07:50 AM
Ringmaster's Avatar
Clean both battery terminals,
Check the tightness of the pos. battery cable on the solenoid,
You may even want to remove the starter and have a look-see at the solenoid, may need some attention in there.
Old Sep 4, 2007 | 07:56 AM
deathrunner's Avatar
Were you mudding at all?
Maybe you got the starter wet and dirty?
Old Sep 4, 2007 | 07:10 PM
nix4x4's Avatar
I went through one pretty serious mudhole a couple times, the rest was just trail-riding and such. I think that I just jarred a battery cable loose or something. Seeing as this problem as never occured with my truck before, I figured I'd ask around and see if there was anything wierd with 3-liters that may explain this.
Old Sep 4, 2007 | 07:53 PM
TNRabbit's Avatar
take off both battery cables and CLEAN WELL. If they need to be replaced, do so. THEN start looking for other problems.
Old Sep 4, 2007 | 07:59 PM
Kaleb's Avatar
You just answered your own question. Clean both posts on your battery.
Old Sep 4, 2007 | 08:12 PM
x-man's Avatar
I went through a muddy water pit and the next day my truck didnt want to start either, whacked the starter couple times and it started right up.....and still starts right up!
Old Sep 4, 2007 | 08:21 PM
stryker's Avatar
x2.
That should work disconnect bolth cables, clean the post's and cables good. Make sure they are tight when they go back. That should do it. Quick and easy troubleshooting!
Old Sep 4, 2007 | 08:22 PM
sdstud212001's Avatar
ahhh whacking it saves the day again...........you know what I mean
Crazychris1871
Jun 27, 2016 10:38 AM
newzingo
Jun 24, 2015 01:50 PM
slider417
Jun 22, 2015 10:18 AM
Beavah
7
Jul 10, 2002 07:18 PM
Corey
Jun 10, 2002 04:23 AM
