weird problem
Old Nov 25, 2008 | 01:35 PM
DudeBud's Avatar
Originally Posted by DeathCougar
When you find the wiring harness connectors, you could just pin the connectors out, then you wouldn't have to cut and splice
that's exactly what i had planned if the pins are the same. you don't have a 89-95 harness laying around do you?
Old Nov 25, 2008 | 02:45 PM
DeathCougar's Avatar
Alas, i have nothing in stock that I can cut plugs off of. If i get a core back any time soon, i can PM you but I don't know when that may be.
Old Nov 25, 2008 | 02:52 PM
DudeBud's Avatar
I'd appreciate it.
Old Nov 25, 2008 | 05:15 PM
abecedarian's Avatar
another thing to consider is the impedance of the injectors.
there are two basic types of injectors, low impedance and high impedance, a.k.a. "peak and hold" and "saturated", respectively. a "peak and hold" ECU can power "saturated" injectors, but not the other-way-'round. mixing or using the wrong injector type can fry the ecu, thus the different plugs on the injectors and harness to prevent the wrong one being installed.
measure the resistance across the terminals in your fuel injectors and make sure you get new injectors with the same resistance. that doesn't mean you won't still have a problem with them, but it dramatically reduces the likelyhood of a problem.
Old Nov 26, 2008 | 05:21 AM
  #25
DudeBud's Avatar
ade... i was pondering that too at work today.. so i think I'm jut going to get a set of 88 injectors.
Jonny246
Jul 24, 2015 12:37 PM
yourrealdad
Jul 21, 2015 11:13 AM
kyletbert
Jul 17, 2015 11:39 AM
icentropy
Jul 14, 2015 10:23 AM
jon.r
Jul 11, 2015 03:34 PM
