Weber 32/36 install question....
Old Oct 20, 2010 | 09:03 AM
PriME87yota's Avatar
Talking Weber 32/36 install question....
Well i picked up a weber for 40 bucks over the weekend. Its amost new and in great shape. Just wanted to know if anyone had any pointers when installing. Anything to look out for ? I have replaced the stock one before and it was not bad so i know this has to be pretty easy.Any advice will help .Thanks
Old Oct 20, 2010 | 09:08 AM
Here is some pics
Attached Thumbnails Weber 32/36 install question....-pdrm0001.jpg   Weber 32/36 install question....-pdrm0002.jpg
Old Oct 20, 2010 | 09:32 AM
xxxtreme22r's Avatar
grrre your gonna actually make me finally put this install up on here aren't ya. lol.
Old Oct 20, 2010 | 09:37 AM
first problem I see, has the wrong throttle linkage on it. Kinda looks like a knockoff weber too.
Old Oct 20, 2010 | 01:34 PM
Well the guy had the throttle rigged up so i ordered the adapter kit for throttle, and a new adapter plate and manual choke kit should be in bye weekend or next week. I belive its a real weber says made in spain, and has weber all over it. Who makes the knock off weber?
Old Oct 20, 2010 | 01:56 PM
Here a few more pics. Dang xtreme u got me worried its a knock off . ima be mad if it is.
Attached Thumbnails Weber 32/36 install question....-pdrm0002.jpg   Weber 32/36 install question....-pdrm0001.jpg
Old Oct 20, 2010 | 02:22 PM
ok nope your good.
there's no electric choke on that?
Old Oct 21, 2010 | 03:42 AM
no its got manual choke. wish it did but i dont mind .lol.
Old Oct 21, 2010 | 04:30 AM
i believe you can convert those to electric.
http://www.lceperformance.com/Weber-...-p/1035030.htm
Old Oct 21, 2010 | 08:40 AM
I wonder how hard it is to convert one? I cant belive your the only one with any input on this lol.
Old Oct 21, 2010 | 08:53 AM
WhiteKnight's Avatar
i just installed a 32/36 last week on my 82. i love it, except its running really rich. i have yet to install a fuel regulator tho, i dont know if thats causing me to run so rich or not.
Old Oct 21, 2010 | 08:58 AM
Do you need to run a regulator? i didnt think the weber needed anymore gas than the stock one? What fuel pressure does the stock use? And what pressure does the weber need?:wabbit:
Old Oct 21, 2010 | 09:01 AM
i was told to run the weber at around 3 psi. i think the stock mech pump puts out around 8.
Old Oct 21, 2010 | 09:20 AM
shouldnt be that hard the coke itself removes pretty easy. the trick is getting it adjusted right.
FYI, there isn't many of us running them, and those that are don't know carbs all that well.
yup this is true. I have mine set at 4psi through a holley regulator though. but I run it at 1.5-2psi when off-roading.
have you followed the weber tuning to a tee. ie set the idle screw to 1-1/2 turns in from contact and the idle mixture screw to 2 and then follow the procedure?
Old Oct 21, 2010 | 09:25 AM
No, i havent tried to tune it just yet. i dont have much confidence in myself when it comes to carb tuning lol.
Old Oct 21, 2010 | 09:26 AM
tuning a weber IMO is much easier than an aisin.
Old Oct 21, 2010 | 09:27 AM
follow this to a tee.
http://www.redlineweber.com/html/Tec...lean_best_.htm
Old Oct 21, 2010 | 09:30 AM
thanks for that link. ill see what i can do lol.
Old Oct 21, 2010 | 09:38 AM
p.s. DO NOT adjust the idle until the mixture screw is fully adjusted. this is important. even if it has a difficult time idling. make sure your timing is set at 0 degrees with the vacuum advance disconnected and plugged (the hose not nec to block off the distributor side) before you start. also important. After you check and adjust your timing then re attach the vacuum hose to the distributor.
Old Oct 21, 2010 | 09:44 AM
Well i dont know what to do, stay manual or get the electric? im sure the electric would be nice when its cold out. I guess ima see if i still have a regulator laying around from an old mustang i had. im supprised the weber needs less pressure than the stock carb . Extreme .. Why do you turn down the pressure when offroad?lol . Thats prolly a noob question . Had to ask neways....
