Vibration at 50mph or higher
Old Dec 22, 2012 | 09:52 PM
some drunk guy's Avatar
1992 Toyota 4runner v6 3.0
Any one know what symptoms are of a u joint going out? I'm starting to get a nasty vibration around 50mph and higher .. If not a u joint what else to look for? Steering wheel does not shake and the vibrating is coming from underneath
Old Dec 23, 2012 | 11:25 AM
shafner30's Avatar
go get the drive shaft taken off and check the ujoints for stiffness i just went thought that the vibration was in the seat and rear end the ujoint next to trans was stiff.
100% it the u joints
Old Dec 24, 2012 | 01:21 PM
mugen2008's Avatar
Had same issue. Is the any noise coming from rear end? Mines was vibrating and making noise. Turns out rear end had to be replaced. Also changed the driveshaft I had and no more vibrations.
Old Dec 24, 2012 | 02:39 PM
ThatGuy1295's Avatar
Just curious if its an auto or manual trans? I have a 5th gear only vibration below 60mph.
Davebarbier
Nov 3, 2015 03:28 PM
shredder4286
Oct 1, 2015 01:09 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
