valve timing
valve timing
my engine has been running really awful since the rebuild and after hrs of searching i went bak to the basics and check the timing. it looks to be off by one tooth. would the engine even have ran at all if he vavle timing was off by one tooth?
Timing
If you need to reference a Service manual online :
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
If it is at the distributor sure but you would be off center on your adj one way or the other and would effect motor , get the motor on TDC on #1 Cylinder and pull distributor and line up to #1 on cap and re-set timing with appropriate shorting technique for timing set ( I believe for yours you short the timing wires leaving distributor).
.Of course someone else may cruise in here and have it so hold on
yes it will run if it is off one tooth. but not very well
put the crankshaft at tdc #1 and the dowel on the camshaft that locates the cam sprocket should be straight up. the mark on the pulley should be 1/2 tooth off from straight up towards the left as you are looking at it.
Timing
If nothing else just remove #1spark plug and get piston on compression stroke and check the rotor button and make sure rotor points to #1 cylinder on cap with the distributor alignment marks (the housing mark at base of distributor and the one on block ) aligned (2 hash marks indicating center of range for distributor housing).
At TDC (Compression Stroke) the rotor will be dead on #1 cylinder on Dist. Cap (should be , if not then its off ).
TDC will be when your timing mark on crank pulley is dead on zero .
Also if you think you are on TDC Compression and check cap and the rotor is pointing pretty much the opposite direction then that will generally mean you are 180 degrees out of the Compression Stroke , just rotate motor one complete revolution and put that timing mark back on zero and that will be TDC Compression
.And if it is off and you have to move a tooth just remember the distributor drive gear teeth are curved so you will have to position the rotor button behind the point you want it to be when you slide distributor back in as it will mesh with drive gear and move before fully seated and stationary , you may find to get it to rest where you want it too you will have to rotate rotor button back a inch and a half or so to begin seating it so as you seat it it will move to the resting place you want it at
well i went back and put the engine at tdc and the dowel on the camshaft was directly at the top, dead on perfect. however, there was a paint mark on the camshaft that would match up with the paint mark i put on the bearing cap if i advanced it one tooth. i feel the need to mention i am no longer using the stock camshaft, i got a 261C from engnbldr. well i set here back one tooth and even though she wouldn't idle, she sounded alot better. i had what sounded like a sticking valve before and that sound is gone, but she's got absolutely no power now. i can barely get into third before she wants to cut off. i'm going out to check the tps now, any other ideas are appreciated.
Timing
I would make sure you are ok there first then move on
.If you had a radical cam I would imagine they would have dialed it in (cam timing) but the dist. is going to mess up your spark timing and will really affect your performance if out a bit
mirror of the fsm up at http://myweb.dal.ca/is353832/93fsm/ if needed.
Jun 1, 2021 01:51 PM
