v6 rear 3rd in 4cylinder SFA
Old Jul 22, 2010 | 07:05 PM
toyotanick's Avatar
all the threads i have found all ask if the 3rd from a 6cylinder 3rd generation will fit on a 4 cylinder of the same generation. but what i really what to know is will the 3rd generation 6cylinder rear fit on a 1980 4cylinder front axle. and of course what to look for and what not.
thanks
Old Jul 22, 2010 | 07:27 PM
tc's Avatar
tc
All pre-95.5 solid axle housings (front or rear) can take either 4 cylinder or V6 thirds. They will even take the high pinion 80-series LC front diff.
Old Jul 22, 2010 | 08:49 PM
toyotanick's Avatar
pre 95.5? what vehicle besides a land cruiser would have a solid axle around that year? and there is nothing i have to look for? other than making sure that the v6 diff is not a 488 gear ratio? anything else will bolt right up, axle shaft are compatable and everything?
Old Jul 22, 2010 | 09:08 PM
toyNG's Avatar
they're both 8", so should be interchangeable.
http://home.4x4wire.com/erik/diffs/
Old Jul 23, 2010 | 05:23 AM
toyotanick's Avatar
yeah i mean that definatelly makes sense. they are the same size so they should be. but also, if they are both 8" ring gears then whats the point of puttina v6 rear end?
Old Jul 23, 2010 | 05:39 AM
blake.nemitz's Avatar
v6 diffs have a two pinion case and two extra spider gears in a solid bolt together case compared to the 4cyl has one pinion running through the spider gears and only has two spiders instead of four
Old Jul 23, 2010 | 05:44 AM
Kaptain's Avatar
Yep, and a bigger pinion bearing as well.
Been running V6 diffs with factory 4.88's for over 4 years. Easy way to 're-gear' without worrying about the set up and plus you have a genuine gearset.
Old Jul 23, 2010 | 07:11 AM
tc's Avatar
tc
My point was that any REAR third works in the SFA too.
The 4.88 rear diff will work in your front housing also. The only thing to worry about with it is that it's not regearable down the road. If you decide to go to larger tires, you have to replace the entire third.
Yes, all axle shafts are 30 spline at the diff end.
Old Jul 23, 2010 | 10:02 AM
skydso's Avatar
Hi,
What do you mean by that? Do you mean that if I have 4.56 gears in my V6 diff, I cannot change to 4.88?
Old Jul 23, 2010 | 10:04 AM
skydso's Avatar
Hi,
What do you mean by that? Do you mean that if I have 4.56 gears in my V6 diff, I cannot change the gears to 4.88 without changing the whole thing?
Old Jul 23, 2010 | 11:06 AM
peow130's Avatar
Up until 95' in australia they had solid axle fronts.
Old Jul 23, 2010 | 04:48 PM
toyotanick's Avatar
hat! thats badass. definatelly did not know that! ok so basically all i have to make sure of is that i do not grab a rear end with 488's stock because the third is built differently and cannot be regeared which i already knew.
just to clarify since all of you have been such a huge help and i figure it couldnt hurt to ask, how do i make sure that i do not accidently find a 488 gear set before i pull it? i think there is a thread on here that i found once on accident through another thread but can manage to get that lucky again.
oh and once again thank you all for being so helpful!
Old Jul 23, 2010 | 04:55 PM
scuba's Avatar
Actually, the year break he is referring to is the 79-95 pre taco vs 95.5+ Tacoma.
What austrailia has to do with this I don't know..
Old Jul 23, 2010 | 05:03 PM
Tofer's Avatar
Sponsor
Originally Posted by skydso
Hi,
re read it again.....
since you said....
Hi,
this doesnt apply to your situation.
Old Jul 23, 2010 | 05:04 PM
Tofer's Avatar
Sponsor
everyone needs to read the stickies.....
https://www.yotatech.com/forums/f116...osting-204178/
Tofer's Avatar
Sponsor
i'm closing this thread before more dumb questions are asked.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
