Uninstall aftermarket cd player 94 pickup
Old May 11, 2007 | 05:09 AM
Killer's Avatar
(thread title specific enough?, and i did a search and couldn't find anything..)
Ok, though this question makes me sound like a complete retard... I can't seem to find how to take out this (looks to be) aftermarket cd player out of my 94 pickup.
i can get the speakers out.. but i can't find any screws/clips/pieces of trim that i'm able to take off to get this thing out.
the problem is i'm getting no sound at all, and i don't think it's the cd player itself, i think there are some wires loose, cause i get no radio/static/anything... and some one had wired up an extra speaker and just set it behind the seat, so i think in a turn it pulled something loose..
(if this needs to be in the electrical forum then i'm sorry, but it's more of a trim/interior question cause i know how the wiring works.)
Old May 11, 2007 | 05:37 AM
magicninja's Avatar
i put in some speakers yesterday. i used this to take apart my dash to access the wires.
http://installdr.com/InstallDocs/Toyota/PDF/869017.pdf
Old May 11, 2007 | 06:04 AM
TNRabbit's Avatar
I'd guess there are screws going in from the side of the unit to hold it in the bracket. You'll have to get up under the dash (remove the bottom part in front of the shifter) to see them. My a/m Kenwood uses four screws. If anyone wants to remove it, they're going to have a helluva time getting it out.
Old May 11, 2007 | 06:09 AM
Killer's Avatar
is all of that necessary to just pull the cd player??
Old May 11, 2007 | 06:10 AM
TNRabbit's Avatar
If there are screws holding it in, yes. It only takes 5 minutes to pull the lower dash.
Old May 11, 2007 | 06:14 AM
Killer's Avatar
oh, the pdf file just makes it look like it would take a lot of work i guess...
Old May 11, 2007 | 06:15 AM
Killer's Avatar
but i can't tell what's holding it in.. i just know that the trim around the cd player is smaller than the player itself, so its over lapping the cd player and i couldn't get the trim pulled.
Old May 11, 2007 | 06:32 AM
TNRabbit's Avatar
ah ha. So you need to pull the trim?
Check here: http://personal.utulsa.edu/~nathan-b.../9instrume.pdf
bottom of page BO-32 shows the screw you need to remove to get the trim panel off.
Old May 11, 2007 | 07:09 AM
Killer's Avatar
thanks man! i should be able to figure it out by one of the two things you posted!!! i hope lol
Old May 11, 2007 | 07:17 AM
Tron's Avatar
Follow the PDF file instructions. It is kinda a pain. But, if you do it wrong you might break something or marr it up.
Unless it was installed wrong you have to take the dash all apart.
Old May 11, 2007 | 07:44 AM
Killer's Avatar
dang.. well hopefully it won't be as bad as it looks...
Old May 11, 2007 | 07:48 AM
TNRabbit's Avatar
Nice lookin' truck, by the way.
Old May 11, 2007 | 08:19 AM
Killer's Avatar
thank you, i just got it.. i'll be honest that i have nothing to do with the way it looks.. i traded for it as is.. so the credit needs to go to the past owner... but i will be fixing it up, cleaning it up.. and doing a few mods... give it a little tougher of a look as opposed to just a redneck mudslingin look. (i live in atlanta, and am more from a small town in north ga and it's nothing but hillbillies.. i don't want to fit in with them lol)
Old May 11, 2007 | 09:02 AM
TNRabbit's Avatar
Do you have a lift kit on it?
Old May 11, 2007 | 09:55 AM
Stevo3's Avatar
Well, It could be the deck. The channels may have blown out on it, which will cause no sound to be heard at all. Just dead silence. But, hope its just a loose wire. Thatll be a lot cheaper than having to get a new deck.
Old May 11, 2007 | 11:18 AM
Killer's Avatar
yeah, not sure on exact inches... but def a body lift.
Old May 11, 2007 | 11:21 AM
Killer's Avatar
yeah, it will.. and i would normally go with a cheapo one, but in this truck.. i would need one that didn't skip in every bump i hit! lol.
Old May 16, 2007 | 02:19 AM
TNRabbit's Avatar
Any luck getting it out?
Road Bull
Oct 10, 2015 04:55 PM
gary4runner
Sep 24, 2015 12:53 AM
Sep 4, 2015 09:27 AM
Suprarossa
Jul 6, 2015 05:21 AM
Vargntucson
Jul 4, 2015 12:15 PM
