truck running rough when OAT below 20
Old Jan 12, 2016 | 06:00 AM
tjunit's Avatar
I live in the Mtns and this winter noticed that my 94 pickup is running extremely rough when the outside Air Temp is around 20 or below. As soon as I drop down into town and the Air temp gets warmer it smooths out and runs fine. Any suggestions?
Old Jan 12, 2016 | 09:57 PM
scope103's Avatar
Any codes?
I'd check the temp sensor in the VAF (THA) http://web.archive.org/web/201003261...92volumeai.pdf
Old Jan 12, 2016 | 10:52 PM
wyoming9's Avatar
Red face
When was the last time it had a tune up??
Even if you let it warm up it runs poor to you lower your elevation ??
Old Jan 20, 2016 | 10:59 AM
tjunit's Avatar
Yes it still runs poor after its warmed up if the outside air temp is cold. It's been awhile since a tune up but not a lot of miles (less than 10000). I haven't checked the codes yet, looking for someone with a reader for that year. I was thinking one of the sensors as well. The weather has since warmed up and it has been running great. But I will check the codes and go from there.
Old Jan 20, 2016 | 01:06 PM
jeremyt's Avatar
unless i'm horribly mistaken 'reader for that year' doesn't exist and the code modules for almost all makes and models has been standardized since some point in the 80's. Any auto parts store should have a freebie code reader for you, it helps their sales and helps their customers
Old Jan 20, 2016 | 07:23 PM
scope103's Avatar
Oh fer cryin' out loud! This is the one thing you really should have done a little searching on.
Your truck is OBD-1. Which means you use the special service tool - usually called a paper clip - to jumper TE1 to E1 on the diagnostic connector. http://web.archive.org/web/201003261...85diagnosi.pdf
Yeah, you can find a "reader for that year," but electrically it's just a paper clip. Starting in about 1995, all cars went to OBD-II. That's completely standardized, but you do need a reader. That's the kind an auto parts store probably has.
Old Jan 20, 2016 | 07:36 PM
jeremyt's Avatar
O gods! now i remember, yeah Ive done paper clip to resets in my old 80s bmw
Old Jan 20, 2016 | 07:43 PM
tjunit's Avatar
I tested the VAC meter (thanks for the link) and found it to be faulty. Thanks for all the help. They are a bit pricy $200 + but worth it if it works. Good tip on the paper clip trick for the obd1 reader
yoder519
Nov 6, 2016 07:18 AM
Thirstypeanut
Dec 11, 2015 04:22 PM
jlangston513
Nov 28, 2015 10:15 AM
Tharpinator
Nov 4, 2015 05:35 AM
allkine
Nov 4, 2015 01:32 AM
