truck pulls the the left very hard
Have a problem with my 94 ext cab Toyota 4x4.
It pulls very hard to the left.
Here is the history that I know about.
I bought it with a 4" lift and 3" body lift with 38" tires. the truck pulled then but I thought it was just the worn out front tire. Anyway, first thing I did was take off the body lift and put 33" tires on it, it still pulled.
Took it to a place that specializes in front end work and they said the tie rods on that side are adjusted as far as they can go.
Can I cut about a 1/2" off each rod so I can get adjustment or is there another way to fix this problem.
The shop would not do anything more because of liability issues.
I got all that checked but that's a good idea. Braking makes no difference to the pull. The shop said the Tie rod ends on the drivers side could not be pulled in anymore. They were bottoming out on each other.
I have a 91' 4x4 that has a similar problem. When I installed a 3" body lift and 33's, I had the frontend alighned. It only pulls when I hit the brakes. A good mechanic friend of mine told me it was more than likely a sticky brake caliper. I plan on replacing the entire front brake system (Rotors, pads, calipers, lines, wheel bearings) in the near future.
if the ends of the tie rods are butting up against each other in the adjuster sleeve, I cant see why you cant take the tie rods to the chop saw and take off a chunk to get more toe adjustment.
22mr2,
That's what I was thinking too. The shop would not do it for liability issues. I'm thinking about giving it a shot, not much to loose either way.
Has anyone else done this?
that sounds weird that they would be bottoming out, i would figure if anything they would need to be longer. anyway, one possibility is if when they installed the lift, they put the pitman arm on off a tooth. I just had an alignment done the other day and the first time it went down the road straight but i couldn't turn as sharp in one direction as i could before. I looked at the tie rods, and one side was way farther out than the other side. I narrowed it down to the pitman arm, it was off like 4 splines! squared away. Yours might be off and need to be centered up and then you would have more even adjustment between the two sides.
IIRC I had to hack a bit off of my Tie rod ends to get it back in alignment after the lift on my 87. I don't remember why anymore I just remember having to give the shop the OK to cut them off
I know you took it to a professional shop, but couldn't they have adjusted the opposite side so that it didn't pull? I would imagine doing so might set your steering wheel off a little, but at least it wouldn't pull.
if it has a big lift and even bigger body lift makes me think it was beat and used off road and with them tyre you said maybe even rock smashing so i say you should look at the cross bar see if its the right one my guess is they bent of broke the stock one and put one from a diff year or something else truck making it longer
if both tie rods are as far as they can go in and it still pulls to the left check your timing on the pitman arm it may be off and also look for problems in the control arms see if there bent THERES NO WAY IN HE!! YOU CAN MAKE THE TIES RODS BOTTOM OUT AND NOT HAVE A PROBLEM ELSE WHERE!!!
so i say take a good look at the front end take pictures post them here and we can look and see with you
I will take picture tomorrow.
Okay,
Here is the read out.
Camber
Left -0.5
Right -1.0
Caster
Left 1.1
Right 2.0
Toe
Left 0.21
Right -0.19
Cross Camber
0.4
Cross Caster
-0.9
Total Toe
0.01
Also, he is what he told me would fix the problem " Shorten tie rods and adjustment sleeves. Caster and camber adjusted as much as possible"
I have no idea what all that mean. Please tell me!
As far as I know, the brakes are fine. The pull is there no matter if I brake or not. It's always the same. I will look into the brakes more.
Also, as far as I know, the tires are good. They are new so I can not look at tire wear and I have tried all 4 tires on the front left.
Okay,
Camber
Left -0.5
Right -1.0
Caster
Left 1.1
Right 2.0
Toe
Left 0.21
Right -0.19
Cross Camber
0.4
Cross Caster
-0.9
Total Toe
0.01
in a perfect world, those numbers should be equal, and generally no more than -0.25 degrees.
Caster: Left 1.1 Right 2.0
as with camber, those numbers should be equal. caster is the primary adjustment that causes the truck to return to 'straight ahead' when you let go of the wheel.
Toe- Left 0.21 Right -0.19
to go straight, does your steering wheel have to be turned slightly to the right?
Cross Camber: 0.4
Cross Caster: -0.9
Total Toe: 0.01
Cross Caster: -0.9
Total Toe: 0.01
if they can't adjust them out, and considering there's a lift kit in there, the suspension/frame may be bent, and if it is, that could explain why there's not enough adjustment in the tie rods
*edited the word camber in the description of caster to read caster
Oddly enough I am having a similar problem only before I took my truck to get aligned it drove straight and after the shop toyed with it it wanders to the left. the reason it went into the shop is the ball joints were shot and it had brake pull. In hunting the brake pull issue my truck now has new rotors, pads, calipers, hoses, fluid, repacked and adjusted bearing and ball joints. the problem is it still wanders and pulls. I am wondering if the alignment guy could have jacked my caster to much making it favor one side or if because I have heavy torsion bars(ride height is slightly higher) could effect it. Anyone elso run into this problem?
bigblue82
10
Jul 6, 2015 08:27 AM
saphirekosmos
Jun 22, 2015 10:26 AM
jmc88runner
Jun 18, 2015 03:39 PM
NerfHerder-97SR5-
7
Jul 12, 2002 03:42 AM
