Truck loses all power until shut off, but does fine with above half tank
Alright....after pulling the tank for the 4th time....I replaced the pump "sock"....Yes it fixed the problem....It just wouldnt allow the flow the pump needed....I figure the reason it started after half tank, is because when it was full, it had enough weight on it to pressure force the fuel in to it....but after half tank, the pressure was alot less, allowing the pump to starve....hope this can help someone else....
kinda related to what some of the Chevys do
http://www.gm-trucks.com/forums/inde...owtopic=110786
Yeah it is sorta the same thing....strange, but figured out for me at least.
I want to know how you could even put a used fuel pump in .
Then never put a new fuel pump sock on. Most likely never looked at it.
Tank comes out for any reason it gets a new pump.and fuel pump bracket and sending unit.
i just throw the used pumps in the Trash .
If any one wants used ones PM me I save them for you!!!
yourrealdad
7
Jul 21, 2015 08:53 AM
sharrack
Jun 26, 2015 09:33 AM
punk1sk8er
7
Jun 24, 2015 01:33 PM
Eagle564
Jun 23, 2015 11:29 PM
