Truck Dies When I Shake It!!!! Please Help!
Old Mar 5, 2008 | 12:43 PM
yotaman85's Avatar
the motor runs very smooth also.
Old Mar 5, 2008 | 12:44 PM
yotaman85's Avatar
is there any wires that run up the passenger side A-piller?
Old Mar 5, 2008 | 12:53 PM
tc's Avatar
tc
No, but the ECU is in the passenger side kickpanel ...
Old Mar 5, 2008 | 01:47 PM
yotaman85's Avatar
the roll was very light all glass is intact save for the windshield could such a small roll damege my ECU?
Old Mar 5, 2008 | 03:08 PM
  #25
tc's Avatar
tc
I doubt it, but you were asking about electrical on the passenger side ...
Old Mar 5, 2008 | 03:14 PM
  #26
yotaman85's Avatar
Right, any other main electrical components around that area?
Old Mar 5, 2008 | 03:18 PM
  #27
yotaman85's Avatar
by the tc you were right about the IFS holding up i wheeled the shat out of it intentionaly trying to break the front end but no luck ( picked up a dana 44 front axle and a GM 10 bolt rear axle FOR FREE! doing a 1ton swap on brother-in-laws truck ) so i guess it will work for now!
  #28
gte718p's Avatar
I got to go with clogged fuel pickup. It may be getting enough wheel at idle, but when you ask for power it cann't provide enough fuel. If rust or crap go suspended in the fuel when you rolled would have taken time to get sucked up into the intake. It just seems to fit.
Old Mar 5, 2008 | 03:26 PM
  #29
flatland4runner's Avatar
I still like electrical for this one. Any chance of a wiring harness or some lights from a trailer hitch, off road lights or electric fuel pump etc. touching exhaust system or something else hot while you were upside down?
Old Mar 5, 2008 | 04:20 PM
  #30
Spence1016's Avatar
you said you lost some lights, so its gotta be electrical, maybe it stumbles when you shake it because wires momentarily touch
Old Mar 5, 2008 | 04:40 PM
  #31
yotaman85's Avatar
thats the idea, but i termanated the only loose wires i could find, come to think of it i did tie up some hitch wires, ill go check
Old Mar 5, 2008 | 05:00 PM
  #32
yotaman85's Avatar
no luck it seams the tail light wires go into the cab just forward of the gas tank is this right
Old Mar 5, 2008 | 07:23 PM
  #33
CyMoN's Avatar
when my truck got flipped on its side then flipped back over the battery got knocked loose some and it pulled one of the wires out of the under hood fuse box.
it also broke the motor mount on the drivers side my truck landed on the passenger side.
my truck would not start when I tried for the first time until I found that wire loose I fixed it and it ran fine after that.
think of it this way a motor weighs 200 to 300 pounds and if it get flipped on its side it will move some in the engine bay and can pull or pinch a wire.
also do a quick check and jack up the tranny and see if the motor moves off the motor mounts all that holds your motor in is a 2 inch piece of rubber on both sides.
Old Mar 5, 2008 | 08:00 PM
  #34
yotaman85's Avatar
I didnt give the whole story. I spent 6 hours replacing both engine mounts, all flud, PS line, pulling off body panels, re-seating 2 tires and tracing the whole harness(save for the taped up tails, but no damage to tape usaully means no damage to wires) not to mention pulling the inner fender and core support back into place and all in the middle of the dessert!! But i had alot of help and should send a 12pack to every one that helped me. But for sure one of the most crazy scrambles to get the truck on the trail i have ever done.
Old Nov 15, 2008 | 09:12 AM
  #35
hooligan750's Avatar
you said you replaced both engine mounts. if they both broke cause of the roll over then you engine was moving around alot upside down, even if only for a minute or 2 it only takes a second to break a wire. you said you dont see any visual damage to wires but wires can be broken by pulling and not show any damage on the outside. the end result of this is the wires touch at rest but when shaken and moved seperate long enough to break connection.
the best way i can think to try and pin point these breaks is a pull test. start the truck and start wiggling and tugging on wires and harnesses rather than shaking the truck this should help narrow down the area to look into
sonic concepts
Aug 16, 2025 03:13 PM
mtrdrms
Jul 17, 2015 02:23 PM
MadMax48
Jul 3, 2015 08:26 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
ibayne
Jun 26, 2015 06:30 AM
