Trouble getting leaf spring bushing out. Need to find replacement
Old May 21, 2009 | 03:44 PM
trbolvr's Avatar
I was thining about a stack of washers?
Old May 22, 2009 | 08:13 AM
trbolvr's Avatar
Here is the result with the washers, drives just like before but I had to pinch the hangar a bit as you can see in the last photo.
isaac338's Avatar
washers don't flex like poly or rubber. just wait for the bushing and save yourself a broken or bent spring or mount.
Old May 22, 2009 | 08:45 AM
Kiroshu's Avatar
not a good idea but can best a fix untill you get bushing because for one all those washers will rust together causing more probs than before and they won't hold long....
Old May 22, 2009 | 08:46 AM
  #25
4banginRunner's Avatar
WTF are you doing?
Old May 22, 2009 | 09:25 AM
  #26
DeathCougar's Avatar
Trying to kill himself
Old May 22, 2009 | 09:15 PM
  #27
Kiroshu's Avatar
^ Sadly this is a true statement... i would not put washers there.... Toyota motor corp. had a bushing there for a reason trust me.
Old May 23, 2009 | 04:35 AM
  #28
flashkl's Avatar
meh... I don't see why that wouldn't hold up for a day as long as the washers are packed in there with no room to move bend and deform. Just get the bushing in there asap and you'll be fine.
edit: wait, did you say you were gonna be wheeling on them washers/?
Old May 25, 2009 | 01:22 PM
  #29
Like i said, trying to kill himself.
He got that thing fixed to go wheeling in.
Old May 25, 2009 | 04:46 PM
  #30
Vitriol's Avatar
wonk. good quck fix. notice the greaseable bolts listed state "dont use with" a steel sleeve. i use mobil 1 synthetic grease on the bolt before it goes it. hasnt dissapeared yet, and if it does get stuck, its not in there for long and comes out whole.
Old May 26, 2009 | 04:58 AM
  #31
trbolvr's Avatar
All is fine now
Old May 26, 2009 | 05:26 AM
  #32
Very sexay! And much safer.
Did you get the greaseable bolts to fit in there as well?
Old Feb 24, 2011 | 07:21 AM
  #33
xxxtreme22r's Avatar
this site is awesome, search and yee shall find. Anyway, searching for 2 hours now and other than a dealer, where would I find the front rubber spring bushing. Not interested in poly. Reports on off-road.com say poly vs rubber can result in about a 1" loss in travel.
And if anyone is curious the actual part number for that bushing is 90389-14004. (48210C in the posted diagrams)
Found this one: http://www.4x4world.com.au/shopping/...roduct_id=3615
note AUS dollar not USD but close conversion. $24 shipping to US. $47.20 AU = $47.55 USD shipped.
Local dealer wanted $35 a piece $70 total.
Toyotapartszone = $57.46 shipped
Toyotapartseast = $54.50 shipped
And yes I bumped a two year old thread. 1 because I searched and found it, and two it's relative to what I was looking for and did not want to be a noob and start another thread asking the same question.
Old Mar 5, 2011 | 12:53 PM
  #34
gonna bump this again, just to say, I am another victim of the bolt seized to the bushing collar. Now taking any and all suggestion how to get these out. Both the passenger side and on the drivers side. Right now I know 100% the gas tank side is not coming out on it's own. Have not touched the easier drivers side as of yet, but expecting the same issue.
Old Mar 5, 2011 | 01:11 PM
  #35
FourwheelinVT's Avatar
Sawzall w/metal cutting blade, cut bolt in between leaf spring and hanger. Be sure to get extra blades, i went through two or three.
Old Mar 5, 2011 | 01:12 PM
  #36
yeah all the threads I found leads to that, but my truck was at someone elses to do it which was my first instinct, but he didn't want me get stuck there.
Old Mar 5, 2011 | 01:17 PM
  #37
one thing I forgot, cutting in between the spring and hanger has the possibility of still having the bushing stuck to the bolt and the bolt head still stuck in the hanger. If it were the passenger side beating on the other end of the bolt on the threads is possible but not the gas tank side.
Old Mar 5, 2011 | 02:21 PM
  #38
4Crawler's Avatar
See the last Q&A on the page below:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.01.html
Old Mar 5, 2011 | 02:25 PM
  #39
thanks 4crawlr saw that too, even tried a pair of vise grips on the sleeve. I am gonna have to cut it out. Or grind the head of the bolt off.
Old Oct 18, 2011 | 07:57 PM
  #40
jonwaynester's Avatar
I need some help. I need rear spring hanger bushings bushings for my 94 toy, I want the bushings that have the 18mm eyelet hole not the stock 14mm hole. Was told that this is possible but I cant seem to find anything. Please help!
