Trouble downshifting from 4th to 3rd
Old Aug 29, 2006 | 10:55 AM
Elvota's Avatar
5spd manual tranny doesn't like to drop back down to third, escpecially trying to keep revs up climbing passes. I can tease or "force" in, but definetly harsh. Feels almost like missing the timing on the clutch during a normal shift. If vehicle slows (under 25 or so), tranny seems to drop down okay.
Any guesses as to the problem? Thinking something internal , but hoping maybe just a clutch adjustment problem. Like maybe the clutch isn't disengaging completely, keeps things spinning that shouldn't be spinning.
Thanks
Old Aug 29, 2006 | 12:14 PM
mastacox's Avatar
Thanks
Hmm, if it was hard to shift into all of your gears, I would say clutch, but only one gear seems like it would be a synchro problem with third gear...
Old Aug 30, 2006 | 01:53 AM
the_supernerd's Avatar
There is a set of bushings on the base of the shifter that wear out after a while and cause difficult shifting. Try searching for transmission bushing or something like that.
Old Aug 30, 2006 | 02:14 AM
TNRabbit's Avatar
I'm pretty certain it's called the "shifter seat bushing" and it is an relatively & cheap (@$5) replacement. I'd recommend trying it before you start tearing into syncros. There is a really good write-up here on it:
http://4runners.org/articles/shift/
Old Aug 30, 2006 | 02:34 AM
Shifter seat bushing sounds right. I am really tired and I could not remember what it was called.
Old Aug 30, 2006 | 02:50 AM
ovrrdrive's Avatar
Did you check the fluid?
I've also heard that the cheap bushing wears out too pretty often. That's definitely cheaper and easier to change than the tranny is...
Old Aug 30, 2006 | 08:37 AM
Pozi's Avatar
Ditto on the shifter seat bushing. This happened to my former Toy PU transmission.
Old Aug 30, 2006 | 11:24 AM
Elvota's Avatar
Thanks for the tips and links. I'll look at the shifter seat and double check the fluid level. I am also going to make sure my clutch is adjusted properly.
What oil does everyone run in this tranny? Synthetic work any better?
Old Aug 30, 2006 | 12:01 PM
mastacox's Avatar
Theoretically AMSOIL is the best (duh) but I run Valvoline 80W90 and haven't had any problems... maybe someone will jump in that has used Synthetic though.
Old Aug 30, 2006 | 12:29 PM
86SR522REEFI's Avatar
brake fluid
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
