Trick to removing decals on a 1st Gen
Old Oct 30, 2013 | 05:06 PM
CarSick?'s Avatar
My Runner's a '94 (Black) that appears to have been garaged kept most of its life but the decals have the usual sunfaded/baked look. Im going to try wet scrapping them down with a razor blade and hot soapy water first, then Im guessing some 1500-2000 wet sand paper will take down the rest enough so i can mask the original decal off and re-paint it (satin black with a silver and red pinstrip along the bottom edege) ....
Old Oct 30, 2013 | 06:11 PM
scope103's Avatar
Try the heat gun first. Worked like a charm for me, and if it doesn't work you can move on to more invasive methods.
Old Oct 30, 2013 | 06:25 PM
ddv1126's Avatar
I used the eraser wheel. It worked perfectly. Don't waste your money on anything else
Old Oct 30, 2013 | 09:33 PM
CarSick?'s Avatar
Would a hair dryer work? How much is an eraser wheel and do you use it with a drill?
Old Oct 31, 2013 | 07:44 AM
  #25
Dan Carey's Avatar
I tried a lot of these "tricks" without much success on my 1989. I ended up using a DA sander to remove them then it went to Maco for a paint job. Be careful when you start a job that can get overwhelming.
Old Oct 31, 2013 | 07:53 AM
  #26
CarSick?'s Avatar
Yea I'm still on the fence about it, I'm going to be re painting over where the original decal was so I really don't need to remove it completely...I'm thinking I'll carefully scrap it with some soapy water and see what that does...if that doesn't take it down enough I could always use a high build primer and wets and it...do they sell the stripe kits still?
Old Nov 6, 2013 | 05:18 PM
  #27
89pickup-pablo's Avatar
GOOF OFF and a razorblade. use the one in an aerosol can! professional grade or smthng. wrked great on my 89 pickup. def a different color under the stickers.
Old Nov 6, 2013 | 06:06 PM
  #28
CarSick?'s Avatar
Sounds like a good idea, I think that's what ill try first. I'll see if auto zone has the spray
Old Nov 6, 2013 | 06:31 PM
  #29
I think u will have better luck at a home improvement or hardware store. Just my .02
okamikai
Apr 30, 2018 10:19 PM
vanion2
Jul 29, 2015 06:17 PM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
