transmission removal problems
well i have a 88' toyota pickup.. im replacing the tranny on it.. its a 5 speed... but theres a problem.. it will not disengage... ive got all the bolts.. i think 6 bell housig bolts.. and 8 crossmember bolts.. and all other necessary attatchments... i have the motor on a jack stands and the tranny is jackeda little to relieve the stress.. i even grabbed a crank and tied a rope to it and to the rear axle to try n force it out.. still didnt budge.. i got all the bolts garunteed... its just not budging... and i searched the website for more info.. but most ppl got theres out after they found out there was 8+ bolts.. but yeah any ideas let me know.. thanks!
Just did my clutch on Saturday.
As I remember it:
Crossmember bolts. (8)
Bellhousing bolts. (7)
Starter. (1 bolt 1 nut)
Clutch slave cylinder (2 bolts)
Transmission and Tcase levers (1 each)
Wiring harness plugs (4)
Front and rear drive shafts (4 bolts each)
Once it's all disconnected you need to give it a tug backwards to get it loose, then lower it.
As I remember it:
if its bound up on the imput shaft because your not supporting its weight it will be virtually impossible to remove...
I started with a pry bar inbetween the belhouseing and block... (but not tring to force the world with it, just work it free)
Is it the same process for removing an auto tranny? I read in the manual it says something about needing 2 "guide pins" in the torque converter.
I guess the good part is, is that the auto will NEVER ben going back in...
If all the bolts are out and external components are out of the way it is either binding on the aligment pins or more likely the pilot bearing in the back of the crank to the output shaft on the transmission. The transmission needs to be in aligngment with the eng. to be removed. Try playing with jack height and use a small hammer and tap on both sides at the alignment pins while someone else is moving the transmisson from side to side. You may want to check the exhaust pipe that has the support bracket to the transmission. I had to remove the pipe to pull the transmission. With the transmission out it is also a good time to change the pilot bearing. Good Luck!!!!
make sure you block the engine or you'll never get that thing out... also.. I usually throw a come-along from the rear of the tranny to the rear axle... you DO NOT want to pull it out with the come-along, just snug it up... I then put my foot on the tail of the T/case and push towards the door of the truck, that should open up a gap between the engine and transmission.. put something in that gap (ie a large screw driver) and goto the opposit side you put the screwdriver in so that it acts as a fulcrum. one more push with your foot.... lower it down and your done. hope that isn't to confusing -Hiriden
trying to mount the engine to the tranny 22RE&Auto
:pat: i have the opposite problem, got the engine out, drive plate and torque converter, came out with it. I took the converter off the drive plate and tried to mount it back into the bell housing. (auto trans)
no luck. I cannot get the rebuilt 22re engine to re-connect with the tranny. i have a feeling the the torque converter is not all the way in. Is there something i am missing? How do i know if the converter is seated properly? Can anyone help? i have my engine ready to go in, and i somehow can't mate it up to the trans. Thanx in advance.
87 4runner
22re
automatic
IFS
LC E Header
High output Alternator
3" lift
no luck. I cannot get the rebuilt 22re engine to re-connect with the tranny. i have a feeling the the torque converter is not all the way in. Is there something i am missing? How do i know if the converter is seated properly? Can anyone help? i have my engine ready to go in, and i somehow can't mate it up to the trans. Thanx in advance.87 4runner
22re
automatic
IFS
LC E Header
3" lift
Clutch lined up correct??
Just how close are you??
Angle of engine and Bell housing is not lined up like it should be.
Top of the bell housing hitting the floor
Splines not lined up quite yet sometimes it needs a little movement of the input shaft.
Wrong Clutch and the splines don`t match.
In this day one needs to inspect every part in the kit.
Transmission clutch lever clip
As I remember it:
As I remember it:
Got my old out and new/used G52 transmission in, although I wasn’t sure about the clip that was on the clutch lever. The one the slave unit moves had a clip fall out and I never saw where it goes on reassembly. As of right now I can still unbolt and take off with no loss of fear fluid because I have been scratching my head all day and night. Thinking it clips on to the end of the inside y clutch bracket that pushes the bearing to disengage the clutch. But I have no idea. Any help would be much appreciated. Thanks in advance
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
