Tranny Kickdown Cable
Old Jan 2, 2008 | 12:42 AM
az4x4runner's Avatar
Question Tranny Kickdown Cable
Ok, a long time ago I adjusted my kick down cable so that the small metal bead on the cable was out a bit further than spec. at WOT.
I had my tranny serviced recently and they mentioned some metal shavings in the pan and I got paranoid.. so...
..tonight I adjusted it back to what I believe is stock spec, but I can't find my manual.
From what I understand, the metal bead is supposed to be 0-1mm from the end of the rubber boot at WOT. Is this correct? And by WOT they mean opening the throttle all the way from inside the engine compartment? I don't have anyone available to stomp the accelerator pedal for me right now.
Thanks for any input, I cannot afford a tranny rebuild anytime in the near future.
Old Jan 2, 2008 | 07:03 AM
InternetRoadkill's Avatar
You are correct. Just work the throttle plate directly on the throttle body to adjust the kickdown cable.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
Rcbc92
Sep 26, 2015 03:00 PM
