Tps swap gone awire pleez help
Old Mar 21, 2009 | 05:16 PM
DIRTYBOYZRACIN's Avatar
Ok i got a 87 22re i kept gettin code for tps so i checked it,found that it sticks half way so i put a new one on.didnt change anything else just tps,when i crank it it instantly shoots to about 4k and bounces like on a rev limiter,i checked everythying,i put the old one back on it crankd and idles fine just like before but now it wont go over 2800rpm im stuck pleez help
Old Mar 21, 2009 | 05:27 PM
sas'd22re's Avatar
did you adjust it as per 4crawler.com? you need to adjust it at various positions. i actually just checked mine about an hour ago
Old Mar 21, 2009 | 05:29 PM
abecedarian's Avatar
did you get the correct TPS?
There are at least 2 different TPS part numbers I'm aware of, and possibly more.
Old Mar 21, 2009 | 06:04 PM
Flash319's Avatar
If you had to turn the new TPS to get it on then it is the wrong one. The two types are 90 degrees different.
Old Mar 22, 2009 | 10:17 AM
I did have to turn it a little to get it on it was holding the throttle a little open so i figured it was the wrong one but why would it not want to rev up past 2800 with the old one now?
Old Mar 22, 2009 | 10:21 AM
Flash319's Avatar
If you only had to turn it a little it should be the right one. You would have to turn it 90 degrees if it was wrong. Sounds like a AFM problem but you say you swapped it......
Old Mar 22, 2009 | 01:06 PM
Yea the truck ran good just was hard to restart because the old tps wouldnt return to 0,when i put the new one on it would crank and instantly run up to about 4k i thought it might be bad so i put the old one back on and now it wont rev past 2500 it cranks good and is smooth until then but at 2500 it bounces like on a rev limiter i set the tps and checked timing im stumped beyond belief
Old Mar 22, 2009 | 01:43 PM
Flash319's Avatar
That bouncing is the fuel cutoff. Do you have your temp sensors plugged in? I know that once in "open loop" a high idle will cause the bouncing idle but up at 2500 I am not sure. Is the truck an auto or manual? Auto's might do that because you are in park.
Old Mar 22, 2009 | 01:53 PM
The temp sensor is plugged in and its a manual its the craziest thing ive ever seen the tps is set(per 4crawler) the timing is dead on as soon as you bump the starter it fires right off idles at 750-800 and has instant throttle response just wont rev i need backup call in the troops lol
Old Mar 22, 2009 | 03:04 PM
Flash319's Avatar
VSV valve not connected right? Do a search for fuel cutoff.
Old Mar 22, 2009 | 03:07 PM
Ill give it a shot and let you know thanks flash
Old Mar 22, 2009 | 04:18 PM
Ok heres what i got so far the new throttle position sensor was bad so i reinstalled the old 1 now it wont rev past 2k ive checked the timing,tps position,afm and even ran a fuel pump jumper wire to eliminate the possiblity of a fuel cut off problem, i removed the trottle body and cleaned the butterfly and all ports ive sprayed the whole motor down checking for air leaks and still got nuthin ne ides?????????(oh yea the old tps wasnt even bad it was stuck i removed it and cleaned it and it works fine now)
Old Mar 22, 2009 | 06:22 PM
Take your TPS off...
figure out which way the throttle plate / shaft moves when you press the pedal down
rotate your TPS 90 degrees in that direction
slide the TPS on to the throttle shaft / body
rotate your TPS back the other direction until the screw holes line up and put the screws in
adjust the TPS.
the mechanism in the TPS is spring loaded so you can't just slide it on the shaft and call it betty.
you have to make sure that the throttle engages the TPS all the way from idle to WOT.
Old Mar 23, 2009 | 09:14 AM
I did that and it works fine everything acts normal until u hit 2k then it just bounces and it does it no matter where u hold the throttle not just wot im completely lost on this one
Old Mar 23, 2009 | 11:33 PM
Ok so i thought i would do a little pokin around tonight when i got home from work so i got out my trusty hanes manual( i know u dont like hanes abe) newayz my temp sensor and secondary coil wouldnt olhm out at all and my distibutor was way off i need some advice what gives could all this crap actually quit working at one time??????????? Abe, flash nebody
Old Mar 24, 2009 | 04:49 AM
Flash319's Avatar
So when it gets to 2k it starts bouncing right? Are you sure that you hooked the vacuum lines up properly? The ones around the throttle body? Try pulling the vacuum line off the fuel regulator on the fuel rail.
Another thing to check is that the E1 to IDLE switch in the TPS opens when he throttle starts to open (resistance is low at throttle closed then jumps to infinity when you start to open).
Old Mar 24, 2009 | 10:02 AM
Ok here we go again i checked all vacuum lines i went to pull apart this mornin and got all kinds of stuff i swapped the afm,temp sensor,o2 sensor, and what ever the sensor on top of the thermo housing is and it did not change it idles alot better but still wont go over 2k( i swapped everything 1 at a time resetting ecu between everything) i olhmed out my pickup in the dist. And it checked out at .287 hanes says it should be between somethin like .140-.180 could this cause the problem im having? Oh yea and thanks for tryin to help thru all this im know im a pain in the ass!!!!!!!!!!!!!!
Old Mar 24, 2009 | 04:31 PM
Nebody?????????????????????
Old Mar 24, 2009 | 06:29 PM
d71889b's Avatar
wow....i'm sorry
Old Mar 26, 2009 | 07:50 AM
This thing is crazy i tried a diff. Ecu and coil off another truck last night and still no fix i cant think of nething it could possibly b
