TPS Adjustment?
Old Jan 20, 2010 | 11:58 AM
alil2cul4u's Avatar
TPS Adjustment?
I was told when I replace my TPS I have to adjust it? I was wondering if someone can tell me how I adjust or align the thing? Im going to pick it up now! I had to order it!
TIA
Old Jan 20, 2010 | 12:43 PM
OutlawMike's Avatar
All you need to know at the link to 4Crawlers site.
I would recommend replacing the screws with either cap heads or torx drive, the phllips drives are bear to remove.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jan 20, 2010 | 01:02 PM
alil2cul4u's Avatar
Thanks, I ended up not needing it! It got it on, and it runs TONS better! Im so happy I got to do this work! This week I've done 02 Sensor, Tune Up, Oil Change, Shocks, and TPS. And It all made it run sooooo much better! I'm so thankful for this forum, everyone is so nice and helpful!
Thanks
Old Jan 20, 2010 | 03:26 PM
OutlawMike's Avatar
Thanks
Just some advice, if you replaced the TPS with a new one, you will need to adjust it for the EFI to work properly. The biggest issue is the EFI system knowing when the throttle position is at idle and when it has just come off of idle. Unless you got really lucky putting the new on one exactly in the right spot, most likely you need to measure the resistance at the terminals and rotate it a bit.
That is from my experience with the things.
Good luck,
Mike
Old Jan 20, 2010 | 03:37 PM
Teuf's Avatar
You said you didn't need it, then got it on? Is a new one on or not, and or did you adjust it?
Thanks
Old Jan 21, 2010 | 10:13 PM
alil2cul4u's Avatar
I was told there wasn't an adjustment... that I just had to put the new one on exactly how the old came off..
Old Jan 22, 2010 | 04:17 AM
TORTIS's Avatar
aaaaa. no. go to 4Crawler site, and it will tell you how to adjust the TPS. Not hard to do, just seems like it takes three hands to do it.
Old Jan 22, 2010 | 12:34 PM
joeynational's Avatar
not true, like everyone else said it needs to be adjusted, get yourself a manual..it has to have a certain amount of Ohms in different throttle positions
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
