Toyota IFS Knuckle seal HELP
Old Jun 16, 2015 | 01:38 PM
Chooch's Avatar
Looking for a part number for the knuckle seal for an IFS truck.
Its the seal that seals the inner spindle bushings, picture below.
I found the Toyota part number for it which is 9013660004
I am looking for a non OEM part number for this seal as Toyota wants $60 a piece....
I know they are available, parts stores are no help and I can't find anyone who has changed the seal and kept their receipt. I desperately need this seal. Help is appreciated!
Old Jun 16, 2015 | 03:34 PM
osv's Avatar
osv
are you sure that is a valid part number, no results on a google search
Old Jun 16, 2015 | 03:55 PM
millball's Avatar
The correct Toyota number is 90316-60004
The correct Toyota number for the dust seal on the axle stub is 90304-76005
These are the later type seals, some of the earlier IFS used slightly different seals and these late seals are not cross compatable with the early seals, so this oil seal and dust seal should be replaced in pairs.
I don't know about aftermarket seals.
Old Jun 16, 2015 | 04:36 PM
millball's Avatar
Here is a thread that has a lot to say about these seals:
https://www.yotatech.com/forums/f116...rt-earn-96581/
Old Jun 19, 2015 | 06:54 AM
RustBucket's Avatar
Confirmed that, due to the updated design, you now have to change both. Toyota made that a real PITA.
Old Jun 19, 2015 | 08:58 AM
kcaudill's Avatar
http://shop.advanceautoparts.com/p/n...l+bearing+seal
Inner seal on the knuckle to the spindle, think this is what youre looking for.
Old Jun 19, 2015 | 09:17 AM
millball's Avatar
No, this is the spindle seal,, not the knuckle seal.
This is a standard, common seal, the knuckle to axle stub seals, not so much.
Old Jun 19, 2015 | 09:59 AM
kcaudill's Avatar
Ahhh got cha
Old Jun 19, 2015 | 12:17 PM
scope103's Avatar
Is this the part(s) you want:
Amazon.com: 9031660004 - Oil Seal Kit For Front Axle Overhaul For Toyota: Automotive Amazon.com: 9031660004 - Oil Seal Kit For Front Axle Overhaul For Toyota: Automotive
I have not delved into this, so I can't directly help. I found this amazon listing just by googling one of the numbers provided by millball. The price is attractive.
More interesting to me is the results from http://www.toyotapartsoverstock.com/...ssembly=512929 They show that there are several part numbers all pointing to the same product. It's worth examining this site, at least for the drawings.
Let us know what you end up with.
Old Jun 19, 2015 | 03:05 PM
millball's Avatar
Looks like the Amazon listing contains a knuckle seal and the inner brass bushing as well.
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
