timing issues..
Old Nov 25, 2014 | 03:52 PM
orig89pckp's Avatar
timing issues..
Hello all. New to site, I need help with my truck. I have a 89 Toyota pickup 3vze. I had the famous head gasket problem so I rebuilt the motor. I got the motor all back together and running smooth, fires right up. However when I go to time it the timing mark on the HB is way off.. How I dont know. But the truck runs and drives ok, has power but doesn't seem like before. Any hints on to what this could be? I went through the FSM multiple times and had someone check my work and everything seems correct. Help would be greatly appreciated, thanks
Old Nov 25, 2014 | 05:07 PM
millball's Avatar
Idle timing cannot be set properly if the TPS is out of adjustment.
Old Nov 25, 2014 | 05:08 PM
RJR's Avatar
RJR
Two things have to be correct for the FSM timing procedure to work.
- You have to have TE1 shorted to E1 on the diag connector
- The TPS has to be adjusted properly such that the idle switch is actually closed when the engine is idling.
Those two conditions tell the ECU to stop mucking with the timing so you can adjust it without it moving all over the place.
Old Nov 25, 2014 | 06:19 PM
orig89pckp's Avatar
The tps(throttle position sensor?) Was never touched but does it need to be adjusted after a rebuild? And I had those two terminals shorted like you say. The timing mark doesn't move around. Its just way off mark. Also tdc of cyl 1 on compression stroke doesn't make the HB mark line up on the 0
Old Nov 25, 2014 | 07:16 PM
orig89pckp's Avatar
For anyone else who may ask this is what has/is done to the truck
-complete motor rebuild kit from LCE
-new piston heads, rings, crank bearings, freeze plugs, oil pump, water pump, ALL gaskets new, timing belt, tensioner..maybe something else
-new fluids
-radiator
-clutch
-Heads shaved to straighten, valve lash checked.
-all new vacuum lines
-upgraded 4 hole injectors
-cold air intake
-EGR delete kit from LCE
-Doug Thorley headers
Timing was done to the book, I have Chiltons book for the truck, also printed Toyota repair procedure. all pulley marks line up and always match up every two revolutions.
The truck starts right up and idles smooth, revs good.. just have no clue where the timing actually is because timing marks on HB dont line up.. is it possible to put HB on wrong, i didnt think so seeing its key'd
Thanks in advance
Old Nov 25, 2014 | 07:37 PM
RJR's Avatar
RJR
I believe it is possible for the two parts of the harmonic balancer, which are joined by the damping material, to slip relative to each other, giving you a timing mark that no longer lines up. This issue has been discussed elsewhere on this forum in the past. A search for "harmonic balancer" may turn up more detail.
You may need to visit a salvage yard for a replacement harmonic balancer.
Old Nov 25, 2014 | 07:47 PM
orig89pckp's Avatar
Okay thanks, I will check it out!
Old Nov 26, 2014 | 07:47 AM
RJR's Avatar
RJR
Here is a link to this problem. https://www.yotatech.com/forums/f116...lancer-218559/
Old Nov 26, 2014 | 08:15 AM
scope103's Avatar
Before you do that, you might line up #1 on TDC, put a mark on the old Harmonic Balancer where zero SHOULD be, and see if your timing is close. (you can get a "paint pen" at lots of art supply stores, or a "wite-out" pen works too).
Don't be surprised if the mark moves around too much to set the timing correctly; if the outer collar is slipping it's because the damping material is torn (or something), so it might be wiggling all the while it's running.
You'll still need to replace it; you don't want the HB to come completely apart at 5,000rpm.
By the way, how did you remove the crank bolt? I've heard some suggest wrapping a chain wrench (or a piece of fan belt bolted to a 2x4) around the harmonic balancer to resist the torque of undoing the bolt. If someone had done something like that during the life of your engine, maybe that caused the damping material to shear.
Old Nov 26, 2014 | 11:40 AM
orig89pckp's Avatar
Thanks RJR I guess I'll be ordering a new one. And scope I took it off with an impact gun when the motor was out of the truck.. But I don't think that's what caused it, due to the fact it was the same before I touched the motor at all.. I will order a new one and see if that works. Thanks fellas
Old Nov 26, 2014 | 12:58 PM
1833CJD's Avatar
Truck Issues
Hey all I'm new to the site and not very familiar with Toyota trucks, with that being said i picked up my sister in laws 1993 Toyota pickup v6 3.0 efi with 254,000 miles for free. A buddy and i pulled the heads had them resurfaced and did all the gaskets and seals did an oil flush and coolant flush. While doing all of this i checked over the engine and everything looked in good working order for the mileage. We got it all assembled the other day and now she wont start. I checked air fuel and spark and she has all three but still no luck any suggestions?
Old Nov 26, 2014 | 01:18 PM
scope103's Avatar
ignition timing is the easiest place to start. Just because you have spark doesn't mean it's at the right time.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
