ticking nosie
Old Aug 27, 2007 | 09:48 PM
blue87's Avatar
ticking nosie
after my 22r has been run for a while and is warm it makes a ticking noise. sounds like its coming from the front of the motor.
is this just a valve noise?
should i adjust the valves or is it just a normal noise ?
Old Aug 27, 2007 | 10:54 PM
x-man's Avatar
So do I, but mine is coming from the trans! when i push the clutch in little bit, it goes away.
Old Aug 28, 2007 | 01:22 AM
drew303's Avatar
throwout bearing
Old Aug 28, 2007 | 07:18 AM
keithguts's Avatar
Just be sure it isn't a fuel injector making the ticking. This was my case in my rig. I though for sure it was a valve, but I was wrong.
Old Aug 28, 2007 | 09:08 AM
thook's Avatar
Where's your oil level at? When was the last time the valves were adjusted?
It could be the valves, but it could also be the timing chain. Does the noise get worse or go away upon acceleration? If the timing chain has broken through a guide it will hit the timing cover also producing a noise.
Generally the timing chain only makes noise upon start up (or in the above scenario), but can also make noise sitting at idle like at a stop light or something. That's from slack in the chain due to age. It doesn't necessarily mean anything is wrong, though. It may be just fine....as in the guides are still intact. Mine was doing that (the timing chain), but went away once I adjusted the valves....and so did any valve noise.
Old Aug 28, 2007 | 09:36 PM
blue87's Avatar
thanks guys.
any tips on adjusting the vlaves on a 22r ,
this is my forst toyota, iv always worked on old chevys so is there a different way of doing it?
Old Aug 28, 2007 | 11:32 PM
x-man's Avatar
Originally Posted by drew303
throwout bearing
will check, thanks!
sorry for kind of jacking the thread.
Old Aug 31, 2007 | 07:43 AM
blue87's Avatar
so its ok to drive with this noise ???
Davebarbier
Nov 3, 2015 03:28 PM
kawazx636
Sep 29, 2015 08:22 AM
Tacoma1313
Sep 15, 2015 07:51 AM
ErikZ1220
Sep 10, 2015 04:53 AM
cars-guy
Jul 11, 2015 07:51 PM
