Throwing error codes.. 3rd time getting this one
Old Jul 25, 2013 | 12:31 PM
Edionne13's Avatar
http://youtu.be/uCzY3D6VTBE
I can't find what's wrong just replaced valve cover gasket did spark plugs. Just replaced AFM from a 91 4runner.
Old Jul 25, 2013 | 12:37 PM
Team420's Avatar
You didnt mention if you have the 3.0 v-6 or 22re....
Its a trouble code 71 tho...
either way, its the same...
Egr system malfunction
• Open in EGR gas temp. sensor circuit
• Open in VSV circuit for EG R
• EGR vacuum hose disconnected,
valve stuck
• Clogged in EGR gas passage
• ECM
I had this a few years back, and just deleted my egr system.
Plenty of threads on here with instructions.
ETA: If you live in a state with smog restrictions.... you will want to correct the issue, and NOT delete the egr.
Old Jul 25, 2013 | 12:45 PM
Edionne13's Avatar
3.0 no smog restrictions
Old Jul 25, 2013 | 01:03 PM
Team420's Avatar
well then... the cheap fix is to delete the egr system.
The CORRECT fix however, is to figure out if its the egr valve, sensor or wiring, vacuum hose/leak causing the issue, and repair/replace accordingly.
Time to do some reading. start by searching "trouble code 71" or "egr valve" etc....
THEN, decide which route to take.
ETA: 5 times out of 10, a vacuum leak is the cause, the other 4-5 times, is a clogged egr valve, which is also fairly easy to fix.
Old Jul 25, 2013 | 02:28 PM
Edionne13's Avatar
Thanks for your help ill surely check this out I kinda feel stupid to think it was a code 17 which there is no such thing possible. Keep this updated if I have any questions
Old Jul 31, 2013 | 10:32 AM
Edionne13's Avatar
Well mechanic said if he cleans it it could stop the Check engine light so. I'm kinda hesitant about doing that. If there's a thread or few threads to help me take it out would be much appreciated. I'm not taking a chance to get a maybe fix
Old Jul 31, 2013 | 01:33 PM
z31freakify's Avatar
sometimes the egr valve gets stuck hit it with a blunt object, had the same problem with an izuzu trooper I was working on, hit the f'er and code went away and idle went back to normal, I'ts worth a shot, try it..
Old Jul 31, 2013 | 05:05 PM
Edionne13's Avatar
Hit that thing hard as I could still no luck -_-
Old Jul 31, 2013 | 05:12 PM
bone collector's Avatar
I highly recommend to delete the egr/pair system on the 3vze. It likes it, and responds MUCH better without it.
https://www.yotatech.com/forums/f116...eaning-259045/
https://www.yotatech.com/forums/f116...emoval-202562/
Old Jul 31, 2013 | 05:16 PM
Team420's Avatar
for egr removal (skip to the part for the egr)
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
for testing...
http://personal.utulsa.edu/~nathan-b...77exhaustg.pdf
Your new best friend
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Gamble_STi
Jul 7, 2015 07:54 PM
skoti89
Jul 6, 2015 07:45 PM
