temp sensor going nuts
ok for the past couple months my temp sensor has been bouncing. it hasn't been consistant until now. It constantly bounces between the cool and middle of the temp guage. I haven't really tracked down if there is a pattern between when it bounces but it does seem like that the sensor goes to the cool zone when i put the pedal to the floor. Any thoughts?
But your right, start with the coolant.
I wish I could give you more info on the location, but I have a 22RE that has been jury-rigged and some of the wires are not original.
For the 3.0, the sending unit is on the back side of the motor (thermostat housing is on the front side) behind the plenum on the right side of the heater hose. One wire goes to it. O'Reilly has them dirt cheap....less than $20. Maybe less than $10, but I don't recall exactly.
BTW, not to hijack, but Tdubbs....how are those Dueler A/T's working for you? Are you still running them?
theking11863
Mar 19, 2016 09:36 PM
rjtrials
Aug 6, 2015 07:25 PM
