tans stuck to block?
ok im trying to put in a new clutch and i have done everything that the book says about removing the trans. Im at the part where you should be able to pull the trans away from the block, but its not moving. I have removed all of the bolts and everything. Does it just require more force like when parting the drive shaft flanges? 95 4runner sr5
Make sure the angle is right. I just did this job myself for the first time last week and had the same problem. Once I raised the tranny up a bit, they seperated fairly easily. Still had to pry gently to get things started though. My center bearing was in pieces once I got in there, so that may have been part of the problem.
i got it off and already have the clutch in, but now im having a hard time putting the tranny back up, but i guess you just have to keep trying till you get it right. anyway it got dark on me so i will finish tomarrow. thanks for everyones help
Something I've been using on the past couple clutch jobs I've done. Run a ratchet strap from frame rail to frame rail under the output of the trans and another looped under the bellhousing. Then you can raise and lower the front and back of the trans independantly. Plus you can slide the straps front and back on the frame rails. This has cut sooo much time off my jiggle-jiggle routine trying to trannies to line up.
JookUpVandetti
Sep 11, 2015 09:41 AM
lfcarrion3
Jul 18, 2015 04:05 PM
