Taillight Bulb
Old Mar 22, 2018 | 02:35 PM
bklf7's Avatar
Taillight Bulb
I’ve got an 87 pickup and trying to figure out what the small bulb in the bottom of the taillight housing that is circled is for. I’ve put new bulbs in on both sides and they don’t lite up. Not sure if I’m not turning the right thing on. Any help would be appreciated.
Old Mar 22, 2018 | 03:24 PM
old87yota's Avatar
That small bulb is a side marker light and is part of the tail light circuit. It is supposed to illuminate when the rest of the tail lights/parking lights are turned on (first click-stop).
It is really there to help illuminate the side of the lamp assembly for visibility and regulations. It eliminated the need for a separate rear side marker lamp found on the previous generation of trucks.
What bulbs are you using? Incandescent or LED?
My Owner's Manual says it is a 194 type bulb.
Check the bulb sockets as well as the connector for the tail light assembly for corrosion. Double check that both new bulbs are actually good.
Old Mar 22, 2018 | 03:59 PM
bklf7's Avatar
I’m using incandescent. Now that I know what It is for a light I will dig into where the problem. Thank you
Old Mar 22, 2018 | 07:19 PM
RAD4Runner's Avatar
Like old87yota says^^^
Pls see my signature, too.
Old Mar 22, 2018 | 11:18 PM
wyoming9's Avatar
Red face
Always good to check if this has a trailer light converter box they cause all types of light problems .
If I remember there is a Tail light harness plug behind the left tail light
Old Mar 23, 2018 | 06:25 AM
atcfixer's Avatar
5 Year Member
If you get to the point of checking wiring, the tail light harness disconnects under the passenger side seat. You might need some extended leads to test the harness. From my experience, the end of the tail light harness is hacked up behind the tail lights in 4/5 trucks because someone tried to install some shotey trailer light kit made for a domestic and those kits almost always come with scotch locks. If your wiring is shot behind the tail lights, I make pig tails for them, if it's really bad I can make long pig tails, or the whole harness minus the cab connector (haven't source it yet).
Old Mar 23, 2018 | 07:03 AM
bklf7's Avatar
I actually had that whole harness out and re wrapped it and didn’t see where anybody had a trailer wire harness installed. I’m going to test the socket first and go from there.
Old Mar 24, 2018 | 02:15 AM
bklf7's Avatar
Got them figured out. I had used some bulbs that were in my toolbox thinking they were new but noooope! Guess they were junk. Bought some brand new ones and what do you know they work. Thanks for the info to help me out.
Old Mar 24, 2018 | 01:57 PM
old87yota's Avatar
I am glad it was something simple like bad bulbs.
I have seen a few people replace some expensive parts when the end the bulbs were bad. That's why I mentioned it.
Old Mar 24, 2018 | 01:58 PM
RAD4Runner's Avatar
YUP. Always start with the simple, the low-cost, before you even take things apart.
Dug
Nov 6, 2006 09:41 PM
Jason B
7
Feb 7, 2005 07:18 AM
guitarsncars
Mar 12, 2003 06:14 AM
yoda-g2
Feb 24, 2003 12:10 PM
runninclean
Nov 6, 2002 05:40 AM
