Tach Install (1989 Pickup 4x4, 22R/e)
Old Mar 5, 2008 | 08:32 AM
87toy.'s Avatar
the light goes into the top left wire.
Old Mar 5, 2008 | 06:31 PM
87toy.'s Avatar
opps, i meant the top right if your sitting in front of it, i was half asleep when i posted this morning
Old Mar 6, 2008 | 08:05 AM
Squiddy's Avatar
Ok re the clock wires. An old post (https://www.yotatech.com/forums/f116...pickup-118009/) has the full clock wire listings. The only remaining issue I got is that on my truck (92 Xcab 3.0) it doesn't seem very obvious at all where on the coil the negative actually is (its all these plug in modules)?
Old Apr 21, 2008 | 01:44 PM
Squiddy's Avatar
Never mind, it is obvious....maybe a pic to follow
Old May 12, 2008 | 06:29 AM
  #25
Squiddy's Avatar
Tach hook up pics
Finally...
...below is pic of hook up to coil. Very simple -- just 2 wires, pos and neg; clip into the negative. Ignore the ignitor attached to coil. Otherwise I did as described in thread -- wires hooked up to clock lines, except for power. There was not enough in clock line, and I have a Painless Wiring fuse block which I tapped into:
Old May 12, 2008 | 07:45 AM
  #26
iamsuperbleeder's Avatar
I use to have the same tach, just mounted on the pillar... now I think I've gone a bit overboard
no the shift light isn't set at 9 1/4 grand, I was just playing with the tach, lol
Old May 22, 2010 | 12:21 AM
  #27
86bedlesstoy's Avatar
Does the 86' 22r has this tach plug as well?
Old May 22, 2010 | 12:56 AM
  #28
drew303's Avatar
You have a green test plug... exactly like this, you run the tach wire exactly like this,
Old May 22, 2010 | 01:18 AM
  #29
Thanks Drew. Kind of really like the sr5 conv. over a tach but still thinking about it
Old May 22, 2010 | 01:28 AM
  #30
drew303's Avatar
I have a 87 bone stock 22r .. well i mean from the factory it was a base model so it had the no tach cluster.. I swapped in a 87 SR5 cluster, ofcourse the temp gauge is fubar (very common they go bunk) but the tach works... it's had some intermitten random skitzo moments where it jumps and falls and skits about.. not sure what that was about hasnt done it in awhile..
anyway, its a direct swap, nothing fancy about it. Just take out the old cluster, swap in the SR5, run a wire from the tach to the test plug. You're set.
Old Aug 10, 2010 | 08:49 PM
  #31
jdmADOBO's Avatar
im new and saw this post ...(bring it back up again, i have a '93 shrt bed 2WD). on the clock wire, there are 4 wires. which wires go to which? except the green tach wire line which goes to the - terminal on the ignition... any suggestion or help?
Old Aug 10, 2010 | 08:50 PM
  #32
85gijunk4x4's Avatar
hey nice tach, i wanna get one
Old Nov 15, 2011 | 12:46 AM
  #33
94 hawk's Avatar
i put an sr5 cluster in my truck not sure how to hook up the tach and the only oil pressure gague i can fidnd they wanted 89 for any ideas
Old Nov 15, 2011 | 11:19 AM
  #34
farmerj's Avatar
I bought the sending unit at the local parts house. You have a choice of buying for a gauge or a light. Just tell them you want the gauge.
I didn't have to do anything to hook up the FACTORY SR5 instrument cluster. It was literally plug it in to the same connector as the non-SR5 cluster and it worked. Factory wiring was already there to do what it needed to do.
Old Jul 21, 2012 | 10:00 PM
  #35
nickxrunner's Avatar
My tach sr5 swap is not going so well. Can I run a wire from the coil as pictured to the back of the cluster to verify the tach is good? Please advise.
Forgot - I have a 92 22RE.
Old Jul 24, 2012 | 09:19 PM
  #36
Anyone?
Old Jul 24, 2012 | 09:54 PM
  #37
Thanks for all the quick responses...
Looks like I found the answer in the this post - for future newbs use...
https://www.yotatech.com/forums/f116...06/index7.html
sonic concepts
Aug 16, 2025 03:13 PM
rondogracing
25
Dec 11, 2015 07:26 AM
bprice0077
Jun 25, 2015 07:36 AM
streetuner15
Jun 18, 2015 10:59 PM
Krash
10
Jul 13, 2002 09:21 PM
