T-Bar mess up ... Help
I was going to to reinstall my stock t-bars instead of the HD's I am currently running. When I picked up my old t-bars I cannot find my markings. Is there any way to tell the difference between right and left. I did notice the head of one of the bars has a little more tapering than the others.
check this out;
http://personal.utulsa.edu/~nathan-b...29torsionb.pdf
You might have to clean them up to see the marks.
Here's what I'd do, remove one side of the bars you have in there now (Downey right?) and lay it next to the old bars and compare the indexing splines. You should be able to see the clocking pattern differences of right vs left. Might help you see it if you mark the indexing spline on each end with paint or something. The indexing splines will be clocked different.
I'd go look at my old OEM bars but they are up in the attic.
I removed them a few minutes ago. I can clearly see a pattern difference between the two stocks, but I can seen no difference between the downey's. The downey's are clearly marked L and R on there heads. I am now looking at it through a magnifying glass, but I wish I had a micrometer. By the way thanks for all your help so far.
you were right
hiluxinargentina
Sep 30, 2015 11:12 PM
