swapping out V6 rear end to 4cyl rear end
i just blew the rear end in my truck. instead of swapping out the gears, my buddy has a rear axle(gears are in it) im gonna swap with instead. my truck is a 6cyl and the new axle came off a 4cyl. mine's an 89 and his is a 93. is it likely that the gear ratio will be the same?
http://www.brian894x4.com/Gearratiosanddiffs.html
http://home.4x4wire.com/erik/diffs/
And besides, how often do carriers actually break before a ring/pinion gear?
this might help: http://www.4x4wire.com/toyota/faq/parts/
Also popping out the 3rd is relatively easy IMO, than count the pinion gear teeth and divide by the ring gear count.
The V6 has a 4 pinion spider assembly where the 4cyl uses a 2 pinion. A locker would replace that part, making them equivalent.
I was referring to the V6 third housing itself that has additional bracing and larger bearings.
Regardless, it's not a huge difference in strength
And now that you've mentioned it, I remember reading that....the part about the spider gears and bearings. Did not know that about the locker. But then, I don't know a lot about lockers....
Anyway, thanks for the info.
Oh, one more thing.......(apologies for the slight hijack)
How would the differences (4 vs 6cyl) apply to a towing application? I'm going to assume heavier duty 6cyl diff would last longer with respect to wear?
I put a 4cyl rear end in my truck because I couldn't find a v6 one at the time. I did that in April, and I've been romping on it ever since. NO problems. I just read in a 4x4ing magazine that people are starting to buy up 4cyl 8" Toyota rear ends with 4.10 gears to put in their off road projects due to the weight to strength ratio and how narrow it is.
Also, some reports I have read say that a select few of the V6's came with a 2 pinion configuration verses the standard 4 pinion. (4cyl rear end from factory). I am going to say from that and my own personal experience, that you should have absolutely no problem.
Clint
Clint
JookUpVandetti
Sep 30, 2015 08:58 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
