suspension travel 1987 toyota
Old Feb 26, 2007 | 09:31 AM
cweich's Avatar
How much front suspension travel will stock 1987 toyota pick-up have?? Is it worth putting a lift kit on if there are no fender clearance issues??
Thanks
Old Feb 26, 2007 | 10:35 AM
MudHippy's Avatar
Big o' wheel wells, gotta love'm. I say go for it, nothin a little, say 1" body lift couldn't fix. I think it should be good without.
Old Feb 26, 2007 | 10:36 AM
deathrunner's Avatar
I believe the 4x4 get's between 6-8". I'm not sure on the exact number.
Old Feb 26, 2007 | 01:29 PM
Yota82's Avatar
Toyota wishes it was 6-8". It's 4.7"
Old Feb 26, 2007 | 05:02 PM
tc's Avatar
tc
Oh - an MOST lifts don't increase that number any, they just re-center the suspension, trading off downtravel for ride height.
IMHO, put 33x10.50 on the stock rims and wheel the hell out of it.
Old Feb 26, 2007 | 05:28 PM
91ToyTrck's Avatar
I'm right there with TC. I just put some 33x10.50 BFG ATs on my truck and within the next month I'll have 4.88s and a rear locker. Stock suspension is more capable then you think. I can't wait to see the guys around my way when I bring her out next time and I'm blasting by them on there 4" lift and 35s, but stuck because they can't hook up.
Old Feb 26, 2007 | 05:45 PM
cweich's Avatar
I already have 36 x 12.50's on my rig. I have included a pic, although I have been raked over the coals for building a rig that is not traditional. But it gets me where I wanna go.
Old Feb 26, 2007 | 06:32 PM
91ToyTrck's Avatar
I'm surprised you haven't SAS your rig ... Is there a reason you haven't? or are you going Long Travel eventually? I'm guessing this is a deticated trail rig as well?
Old Feb 26, 2007 | 06:35 PM
tc's Avatar
tc
Ummm - all that fabbability and tube work and you don't have a solid axle under there?
Well usually, the travel is limited by the factory bumpstops or fenders. Obviously, neither of those need apply to your rig... you are safe to add more compression travel, but there's not much room for droop without endangering the CV's.... and with IFS, more compression travel could just lead to you high centering the front diff, so it may not make sense for hard use.
Other option would be to do a Long Travel setup like Total Chaos.
bigjstang
Jun 2, 2025 03:56 PM
MO transplant
Apr 23, 2023 11:58 AM
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
Vargntucson
Jul 4, 2015 12:15 PM
