Suicidal Starting Problem
Old Jan 26, 2008 | 01:58 PM
95_4MuddinSr5's Avatar
My 4Runner just wont start. i turn the key to on and everything comes on and works as it should but then when i try to start it the clock, radio, and lights go dim. the relay clicks and works(swapped it out with my buddys). Replaced the starter, WASTE OF MONEY $150., still wont start. Tryed jumping it after everything and still nothing. dont know if it is the solenoid wire, ignition switch, or a switch somewhere. wiring somewhere is messed up? Dont know? Anything will help!!!!
Old Jan 26, 2008 | 02:05 PM
4Crawler's Avatar
Sounds like time for a volt meter:
http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Probably have a dirty or corroded battery cable or connection some place. Use the meter to work back from the starter towards the battery. Could even be a bad battery if you find the voltage at the battery terminal drops too low.
Old Jan 31, 2008 | 02:26 AM
farmerj's Avatar
Load test the battery.
If you're really daring, voltage test the cells. Basically, pop the caps and put your probes into each cell. Touch the fluid only, don't push into the plates.
You should see 2.3 volts between cells or about 13.6 across the battery.
Old Jan 31, 2008 | 04:47 AM
MMA_Alex's Avatar
Its probably a battery connection. Its enough to power the accessories in the cab, but when it tries to draw large ammounts of amperage the voltage drop is too large to get the starter to go.
Old Jan 31, 2008 | 04:53 AM
04 Rocko Taco's Avatar
I would say battery on its way out, ot a faulty connection somewhere.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
