strawberry milk in tranny!!
Old Apr 27, 2008 | 03:04 PM
Team420's Avatar
Ok...so I went out wheelin last night, and got myself into a real deep hole, it didnt look that bad untill i got into it, and wouldnt ya know it, the water ended up coming over my hood, any way long story short, I got it out and running, however there is still some water in my tranny, What would be the best thing to do at this point..other than the obvious(Flush it out, new filter etc) do you think that will be enough, or am i going to be looking for a new tranny? thanks in advance.
O... also It sat for about 6 hrs in the hole, and was only driven about 8 miles to get home. and I DO have pics.. ill post the links later on!
Old Apr 27, 2008 | 03:15 PM
DeathCougar's Avatar
Take it to a shop that has a flush machine, have them do a full flush to clean all the water out, as well as putting a new filter on it. And next time, dont drive though the water!
Matt16's Avatar
What did it drive like during those 8 miles. Flush the tranny (maybe even a couple times) and then refill it with fluid. You might be lucky.
Old Apr 27, 2008 | 03:21 PM
mt_goat's Avatar
From what I've heard it takes a lot of flushing. Might want to start flushing with some cheap ATF since it will likely take multible flushes. Each flush can take up to 15 qts of ATF so the $$$ can add up fast. But I'm no expert.
Most of the others I've seen have been radiator ATF coolers that failed and the tranny was filled with coolant. Not sure which is worse The dirt in muddy water could be worse I guess.
Your water was probably sucked in the breather vents or through the dip stick joint.
Good luck
Old Apr 27, 2008 | 03:23 PM
Team420's Avatar
it actually drove and shifted normal, im gonna do the flush myself, the nearest shop is 30 miles away, so grab 3 times the amount of fluid...maybe i be ok? I hope so, already did this a few years ago, and ended up having to replace the tranny, didnt know there was water in it for almost 2 weeks tho, any additives that may help? Thanks for the quick responses
Old Apr 27, 2008 | 03:35 PM
Team420's Avatar
heres a link to a pic on my friends myspace, just to give an idea of how bad it was, my g/f and i ended up lighting a fire and sleepin on the ground till daylight!! what great fun!!lol
http://viewmorepics.myspace.com/inde...ageID=31239956
Old Apr 27, 2008 | 04:36 PM
TOYOTA 1's Avatar
no picture there!
Old Apr 28, 2008 | 08:30 AM
Team420's Avatar
Originally Posted by TOYOTA 1
no picture there!
sorry guys....it worked for me yesterday, but i guess because i was still logged in...Ill try to find another way to post them, it was nasty, water up to the gear shifter in my truck!! and to make matters worse it was a jeep wrangler that pulled me out
Old Apr 28, 2008 | 09:24 AM
chrishf12's Avatar
here you go I fixed it for you
Old Apr 28, 2008 | 12:16 PM
Team420's Avatar
Thank you.
Old Apr 28, 2008 | 12:24 PM
mt_goat's Avatar
I guess you're lucky you didn't hydrolock it too. Maybe it would be a good idea to back into large bodies of water to test the depth.
Old Apr 28, 2008 | 12:39 PM
Team420's Avatar
actually it was hydrolocked.. took me forever to get it cleaned out and started, and now after it being in the garage overnight, it wont start... took the ecm out, and its drying now... not getting spark from distributer, but there is spark from the coil, hopefully I can get it started soon, all that water is still in the tranny, and i cant flush it without the truck running!
And had I thought the hole was as deep, I wouldnt even have tried, but I have taken this trail many times, and its never been like that.. I hear some guys with 37+ inch tires have been going through and tearing it up.
Old Apr 28, 2008 | 01:51 PM
Team420's Avatar
ok, dried the ecm out, I'm getting spark at the plugs, and i can smeel the fuel...so i know its getting both, but still wont start...I dont get it...started and ran fine after when i drove it home yesterday, now it wont fire... is there something i might be missing? any advice is welcomed.
Old Apr 28, 2008 | 02:31 PM
mt_goat's Avatar
Add air and compression and there should be explosions happening. Air in and air out, hey you didn't plug up your exhaust did you?
Old Apr 28, 2008 | 02:37 PM
Team420's Avatar
I dont think so, as I did drive it home..hmmm...it did stall at idle tho...so I guess maybe? any thoughts as to the best way to check that?
Old Apr 28, 2008 | 02:38 PM
Team420's Avatar
sorry...started a new thread for my new problem... I hope that is not going to aggravate any one.
Old Apr 28, 2008 | 02:48 PM
mt_goat's Avatar
Have someone crank it while you put your hand over the tailpipe. Maybe you got some crap clogging the cat.
Old Apr 28, 2008 | 02:50 PM
mt_goat's Avatar
Here is the link to the new thread:
https://www.yotatech.com/forums/f116...rt-now-143875/
Old Apr 28, 2008 | 03:26 PM
nonamer's Avatar
WOW... you have some serious balls driving into somthing like that
Old Apr 28, 2008 | 03:36 PM
Team420's Avatar
LOL...Yeah..liquid balls (guiness).. worst part was having to make my g/f sleep on the ground next to a fire till daylight... it was cold...and she got cranky quick... she laughs about it now though!!
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
