Steering Stabilizer Replacement??
Old May 28, 2008 | 10:30 PM
qdude79's Avatar
Ok, did a search of this forum, looked at local parts houses online catalog, can't find a match!
Pulled the OE stabilizer off the front, as expected, it's shot. Went to Autozone, they tried to give me a replacement with stems on each end (Summit, the same) . Kragen wants to give me one with eyelets on each end. What I pulled off has one eyelet, and the other end looks like a tie rod end. Anyone know where to get one of these?
Old May 28, 2008 | 10:37 PM
netgodsrdn2's Avatar
I ended up using a Monroe from Checker. The hardware was in the box to make it bolt up correctly.
Old May 28, 2008 | 11:41 PM
Matt16's Avatar
The aftermarket units should come with the hardware to mount it. I had an issue with the bolt attaching the steering stabilizer to the relay rod (?) contacting the pitman arm stop. It would sort of catch there. I ground the stop down a bit and it doesn't contact any more.
Old May 29, 2008 | 03:29 AM
abecedarian's Avatar
I went through 4 different rancho and procomp ones from 4 wheel parts- and not one of them were correct- they were either 2 studs or 2 hoops. So I just got them to get one with 1 stud and 1 hoop and bought a shock mount from the Help! section at Autozone and bolted it through the loop on the steering rod where the old stab ball-joint went. That let mount the stabilizer's hoop on that end and the stud through the frame.
Old May 29, 2008 | 06:50 AM
qdude79's Avatar
Man, you'd think with all these companies wanting their shiny logos on the front of as many vehicles as possible that they'd at least offer the right part! Gonna try the Kragen/Checker route the netgodsrn2 went with. If not, I'll have to remain "unstabilized" 'til I figure it out. Why not? I'm unstable in every other way...
Old May 29, 2008 | 06:59 AM
dirtyXplorer's Avatar
My procomp one came free with the shocks that I bought and came with the hardware. If you can spend a little more and buy a nice one like OME or Bilistine (sp?)...When I put on the procomp I didn't notice a difference over my worn out, leaking stock one.
Old May 29, 2008 | 07:41 AM
Beaniam's Avatar
If you want a stock location replacement, get the OME. Also get a pickle fork for removing the stud on the driver side, it'll make things much easier. If you want to use one of the others you got, you need a bracket kit, rancho makes one. I made the same mistake in getting the wrong one the first time so after getting the OME I spent the extra $20 on a bracket kit and run both. Overkill but it does more on the truck than sitting in the garage.
Old May 29, 2008 | 10:13 AM
Snotrocket's Avatar
I used a generic one from Napa and it came with the correct hardware to make it fit. It was a lot bigger and beefier than the stock unit to.
I second getting a pickle fork and a BFH to get it off to.
Old May 29, 2008 | 10:20 AM
qdude79's Avatar
Semi off topic, but I've already yanked the stocker, along with ball joints and tie rods. WAAAAYYYY easier than it was with my old F150! All parts removed in under an hour! Took me a day and a few layers of skin with the F(&rd. Saw a few posts asking about how to remove these... my response: BFH, pickle fork, swing away like it was your ex!
Old May 29, 2008 | 10:45 AM
anotherjeff's Avatar
Just run down and pull one off a wreck at Pick-n-Pull! About $8. There's lots of good, used 2WD dampers around.
Old May 29, 2008 | 10:47 AM
qdude79's Avatar
I'm replacing most every other steering component new, minus the pitman and idler (both solid). Want to eliminate as many weak links as possible.
Old May 29, 2008 | 10:52 AM
Hilux808's Avatar
This is the one that I have on my 4runner and it's been working good. Got it from Summit. Pro Comp ES2000 Steering Stabilizer (Part # 219500). They might have changed the part number but you should be able to cross reference it with this one at their web site. it's a stock replacement for our trucks, bolted right up with no problems. Much better then the stock one.
Old May 29, 2008 | 12:00 PM
Djlarroc's Avatar
That's the same one I just bought. I think I paid like $38 shipped. It installed with no problems. Now that I think of it, I'm pretty sure it came with 2 eyelets though. And a big bolt that went through the mount towards the driver's side with a caster nut.
Old May 29, 2008 | 01:41 PM
Matt16's Avatar
My ProComp ES2000 didn't make too much difference versus the OEM stabilizer. Its maybe a little better, but not sure its worth it unless yours is shot.
Old May 30, 2008 | 07:33 AM
Djlarroc's Avatar
Here's a shot of my new PC es2000. It has eyelets on both sides, I just happen to take the pic with the bolt through one end.
Next to the old NAPA damper
Old May 30, 2008 | 07:44 AM
qdude79's Avatar
Man, I don't know if I need to change my browser settings or what, but this is the second time I can't see a pic! Anybody know what I need to do? I'd like to see Djlarroc's comparo...
Old May 31, 2008 | 08:51 AM
highonpottery's Avatar
i run an OME steering stabilizer and it is damn beefy. comparison of stock to OME would be a hotdog to a salami. OME has 1 stud end and 1 loop end. i even have me a spare one in the box if interested...
Old May 31, 2008 | 10:33 AM
Djlarroc's Avatar
I drove my truck for the first time today since the damper install. I didn't notice much of a difference.
Old May 31, 2008 | 10:59 AM
Brenjen's Avatar
I put an OME from TRD parts in Dallas on mine & it was a world of difference from the stock skimpy shot p.o.j. that was on it & yes, BFH & a pickle fork gets it off easy.
Old May 31, 2008 | 04:44 PM
RobD's Avatar
http://www.offroadtuff.com/ome.htm
https://www.yotatech.com/forums/f129...4runner-75741/
