starter problems again
Old Jun 25, 2010 | 04:50 AM
budlight_87's Avatar
Just bought 89 pickup that wouldn't start unless push started replaced contacts in starter that worked for 2-3 days now it just clicks again but if you tap on starter it starts so bad spot it starter or what
Old Jun 25, 2010 | 06:39 AM
yota864x4's Avatar
i had the same problem a couple weeks ago. i just got a new starter and haven't had problems since.
Old Jun 25, 2010 | 06:50 AM
snobdds's Avatar
Check your battery, if you don't have enough juice to push the plunger inside the starter up it will give you the same problems.
I had the same deal, changed the contacts and it worked for a little while then it made the clicking sound again. Changed my battery and have not had the problem since.
Old Jun 25, 2010 | 06:52 AM
4Crawler's Avatar
Simple electrical test to help you find the cause of the problem below:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Old Jun 25, 2010 | 07:35 AM
X-AWDriver's Avatar
I had a friend say that replacing the contacts isn't good enough of other parts are too worn that can't be replaced. I'm not up to speed of the inner working on a starter outside the contacts so I can't remeber that specific part he said that wears.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
