Is this the starter?
Ok..
My 4runner is having trouble getting started sometimes. Sometimes it will start on the first turn of the key, no problems! Other times when I go to turn the key, it just goes.. click. so I turn it again and again, only to get a click. Of course, It only does this in parking lots away from home.
I thought it was a battery, so I swapped it with one from my pickup, and I hadn't had a problem for about a week or so.
I don't think it's the alternator, because the volt meter on the dash is indicating a charge when the truck runs.
It just displayed this lil problem at the parking lot in wild oats just moments ago. We tried to jump it and it just made the click sound. It doesn't make that normal continual click like a starter though, just one click.
What do you guys think?
Ended up being my battery cables, more specifically the "+" cable connector for the battery terminal. I couldn't get the worn-out POS tight enough with the old stripped-out bolt that tightens it. Felt tight enough, but NOOOO, NOT SO!!!!
Had to replace that little bolt and hammer the lead connector back into shape so it'd grip that terminal better, make more surface contact.
Hey, at least I know how to rebuild my starter now!
Nothing to do with the battery. Exact same symptoms as mine, and several other people in my area. Its the contacts. Paid a Toyota mechanic, works on the side, to replace them. $60.00 here for parts and labor.
Not HUGE, but not that fun, there's a little access panel that helps a little. I tore mine apart recently to refurbish the contacts after experiencing just what you are. Only to find them in not too bad o' shape.
zombie_barbarossa
Oct 2, 2015 10:54 PM
