speedo cable squeek?
Old Nov 22, 2010 | 10:38 PM
runs-on-4's Avatar
my cable squeeks for a good 15 miles when i drive and only when im going over 30 . whats the easiest way to fix this
Old Nov 22, 2010 | 11:18 PM
runs-on-4's Avatar
tried it. i think the inside is rubbing the last owner said he replaced it but it still rubs
Old Nov 23, 2010 | 09:09 AM
runs-on-4's Avatar
alright ill try that thanks
Old Nov 23, 2010 | 10:15 AM
runs-on-4's Avatar
ya thanks
Old Nov 23, 2010 | 10:49 AM
grant526's Avatar
My speedo cable more than squeaked in my 85. I finally figured out the housing had deteriorated from the heat of the exhaust manifold, allowing the cable to wear through the plasted insulation and start rubbing on the braided reinforcement wire within the housing its self. I picked up a used cable for like $20 and swapped it out, it's a fairly simple process. But you have to open up the dash to get the cable end properly installed in the speedo.
Does your speedo "bounce" when it's making that noise? Mine did
Old Nov 23, 2010 | 11:09 AM
richf's Avatar
How do you get the grease inside the cable? Do you just force it in there with a grease gun?
Old Nov 23, 2010 | 12:08 PM
richf's Avatar
Gotcha thanks.
Old Nov 24, 2010 | 09:23 AM
grant526's Avatar
I've heard you can pull speedo cable out of the housing, lube them (with whatever kind of lube) and install them. But you can't do that with Toyota speedo cables. Though it would be nice!
Old Nov 24, 2010 | 02:59 PM
runs-on-4's Avatar
ya it bounces but it only will squeek for about 10 miles
Old Nov 25, 2010 | 12:34 PM
grant526's Avatar
Don't know it you're having same issue, but mine would bouce intermittently as well as make noise randomly. There was never any rhyme or reason to it.
kawazx636
Oct 6, 2021 03:03 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
charlie_fong
Sep 27, 2015 10:06 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
