speedo cable question......
I own a 90' toyota p'up 2wd cab with a 20r motor on a 79' 4x4 chasis with a 5spd 93' tranny....whew....lol...anyways my gauge cluster in the truck is a mechanical cable type and my tranny is electrical.....so how do i plug the speedocable into my tranny without swapping the tranny?
yeah i have no ecu because i have a 20r motor...is there anyway i can remove the speedsensor and replace it with a cable adapterplug or something?....if not what kinda of aftermarket ones are out there?do they hook up to my oem speed sensor?
so it is a 90 cab with a 90 interior/gauge cluster?
if you have a the ele spreedo setup on the transfer case then just wire the 3 wires up to the back of the 90gauge cluster.
if you have a manual input on the back of your cluster you will need a manual input on the transfercase hole.
they are the same hole on the digital speedo plug and the manual just different adapters on the tcase. if it were me i would go digital on both of them.
i got one i just did almost the same thing i have a 93 yota blew the tranny and put a 90 tranny in and there should be a bolt that you can pull out next to the spot where you mechanical one is put in so to the right of where your mechanical speedo plugs in there is a bolt next to that and its where you can plug the electric one in if thats helps idk it its work with your truck because you have the 20r
kawazx636
Oct 6, 2021 03:03 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
charlie_fong
Sep 27, 2015 10:06 PM
