spare tire location
Old Apr 13, 2008 | 07:19 PM
4x4YOTA's Avatar
spare tire location
Ok so I m running 33s and I just got a full size spare and I need a place to put it. It wont fit under my truck in the stock location. So if you could please post some pics of were you have your (33/full size spare) I would appreciate it alot I need some ideas!
I even thought of putting a 4runner tire swing on the rear of my truck. Any one done this ???
Any pics would help! thanks
Old Apr 13, 2008 | 07:27 PM
jasond's Avatar
My spare is a 35 to match the others, so I couldnt mount it under the bed. I had it sitting flat in the bed for a few years before I got tired of cleaning out all the crap that collects underneath it. I made this out of 1 3/4" tubing and some rectangle tubing that I had found. I made it so that if I pulled out the pins closest to the cab it would sit flat (so I could put my dirt bike in the back w/o removing the spare) I like the extra room that it freed up and now my spare is secure from theft.
I made the pins out of some wing nuts and some round stock that I welded together because I couldnt find any of those quick release pins in the right length at the time, and since then I have been to lazy/cheap to find the right ones.
To mount the tire, I used all thread through the middle of the center rectangular piece - after I sleeved it. I used a nut on each side of the rectangular piece to keep it in place. I welded the nut that faces down to keep it from backing off. Then I cut a piece of diamond plate round to hold down the tire and welded a nut inside of that. I drilled out the all thread on the tip to add a lock.
Old Apr 13, 2008 | 07:35 PM
4x4YOTA's Avatar
how is it as far as weight? my truck is my DD and I need to keep it light!
Old Apr 13, 2008 | 08:12 PM
94Runner4x4's Avatar
that looks awesome man! but as far as my spare it sits in my closet and I only take it out for long trips. I figure if I'm close to home it's no big deal to me to walk, but i can easily find a ride too.
Old Apr 13, 2008 | 08:33 PM
DCYota's Avatar
I keep my 33 in the bed for now. I have a friend that's going to make me a carrier similar to the CBI Offroad one that will go in the 2" receiver on my All Pro bumper. Otherwise, I have no problems with it in the bed.
Old Apr 13, 2008 | 09:11 PM
Brendan's Avatar
a 33x9.5 will fit under the bed and it's lighter too
Old Apr 14, 2008 | 02:43 PM
jasond's Avatar
It's really not that heavy, I think that the tire/wheel weighs more than the rack that I built does. I used .095 tubing, but that was because its what I had left over from a previous project....mine is also a daily driver.
Old Apr 14, 2008 | 03:18 PM
Junkers88's Avatar
So a 10.50 won't make it in there? Crap that changes my tires..........
Old Apr 14, 2008 | 03:22 PM
traben27's Avatar
A 10.50 will fit, I had to cut the brackets off toward the rear of the vehicle (left the ones keeping the tire away from the exhaust)
Old Apr 14, 2008 | 03:41 PM
norcalsvx's Avatar
i just toss it in the bed for wheeling trips and it stays at home for just cruising around town
Old Apr 14, 2008 | 03:43 PM
4x4YOTA's Avatar
I think Im gonna go with this advice
Old Apr 14, 2008 | 05:50 PM
Brendan's Avatar
i don't know why a 12.5 wouldn't fit. it would hang down pretty low but i think i it could be done.
Old Apr 14, 2008 | 10:11 PM
4x4YOTA's Avatar
my spare is a 33x10.50 and dont want to put it in the stock location cuz I want to gain more clearence and do something more stylish!
Old Apr 14, 2008 | 10:24 PM
89silverpu's Avatar
Slap that bad boy on your hood
Old Apr 15, 2008 | 10:36 AM
Gonzo4Runner's Avatar
I have a 33x12.5 in the stock location on a 1st gen 4Runner. It does extend down a little bit, but for normal driving (streets and highways), it is fine. It is accessible, but not in the way. If you try to put it there, make sure that the tire is a few inches from the exhaust pipe, and you will have to tweak the rear load proportioning valve arm so that is doesn't get caught on the tire.
If I need clearance, I have a swing-out tire carrier (removable) for my rear bumper for off-road.
Old Apr 15, 2008 | 10:54 AM
4x4YOTA's Avatar
any pics of the swing out tire carrier?
94whiterunner
9
Sep 22, 2015 07:28 PM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
akaphilly
Jul 9, 2015 02:34 PM
skoti89
Jul 8, 2015 12:05 AM
