soldering up a Supra AFM
Old Mar 11, 2009 | 10:21 PM
  #141
Matt16's Avatar
I searched for the AFM adjustments on Downey OR site, but I couldn't find them. Could you post up a link?
I can't say I've noticed any more pinging with mine, but my intake duct is still stock so its really not letting any more air in. Might try richening one click at a time until it stops pining under throttle. If I understand correctly, the O2 sensor has the final say when the engine is in open loop (ie: not at wide open throttle), so the AFM adjustment shouldn't make a difference in regular driving as long as "regular driving" doesn't involve too much WOT.
http://celica-gts.com/resources/how-...djustment.html
Old Mar 12, 2009 | 08:03 AM
  #142
BigBluePile's Avatar
Here's the Downey link, it's pretty basic: http://www.downeyoff-road.com/Engine...Injection.html.
This one has pictures: http://www.4x4wire.com/toyota/minutemods/afm/
"Regular driving" is a relative term! I like the sound of my truck!! The reason I notice the ping was while I was checking for a lag difference at idle. Again, I was curious if others had such a report. I have not notice any pinging during "normal" accelleration. I have not "loaded" the engine either to see if there is a pinging.
Old Mar 12, 2009 | 09:57 AM
  #143
Matt16's Avatar
I wish there was some way to get some type of feedback when adjusting the AFM, aside from seat-of-the-pants.
Old Mar 12, 2009 | 06:33 PM
  #144
What do you mean? Like a dyno? I could put in an air/fuel ratio meter and then I could see what the deal is. I already have too many gauges!!! Or one of these: http://www.toyotacatalog.net/m1webge...C-B9A8537C9B49.
Old Mar 13, 2009 | 01:57 AM
  #145
ffryno13's Avatar
well its my favorite type of diagnostic technique to do its trial and error. oh and get rid of that ignition system cran, MSD or what ever else people have come up with. they won t help at all. make sure when adjust your AFM that you let it run or drive it for a bit to make sure that the ECU took the adjustment
Old Mar 14, 2009 | 08:23 AM
  #146
Trial and error indeed! I pulled the Crane ignition out last night and probably wont' be putting it back in. So, we'll see what that does.
Old Mar 15, 2009 | 06:53 PM
  #147
ffryno13's Avatar
yeah i have heard of more problems with those ignitions then any other type of issue with toyotas.
Old Mar 16, 2009 | 04:30 PM
  #148
Well, I have never had any problems with the Crane system and it worked just fine. I liked it for the options I could use with it, like rev limiter and antitheft. Unfortunetly I just don't notice a difference, but we will see now that I took it out.
MadMax48
Mar 3, 2020 10:33 AM
Gutted91
Jan 3, 2020 09:48 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
toyotasaurus
Sep 24, 2015 03:30 PM
