So i have decided to finaly fix my sag!
Old Feb 1, 2009 | 02:34 PM
Joby8103's Avatar
So i know there is lots of info on here about this so no bashing! I just want your simple opinion on what of the two choices you would pick if you were me.
Choice one, Lift block and New u-bolts
Choice two, Rear shackles
Whick one would you choose and do you think 2" of lift in the back is about right to take out the sag and possibly have the back a little higher?
also, will I need to replace the shocks that are on now and is there any other hidden challenges I should know about?
right now my runner is getting painted! and after it's all done ill post some before and after pics and get your guys and gals opinions! thanks
Old Feb 1, 2009 | 02:52 PM
874runnersr5's Avatar
rear shackles, but..
you should just get some downey leafs... cheap, very good to...
Old Feb 1, 2009 | 03:02 PM
Joby8103's Avatar
so with new springs what else would need replaced? and anyone use there torsion bars? how much front lift could i get with them?
Old Feb 1, 2009 | 03:15 PM
abecedarian's Avatar
Are you looking to fix sag or get lift?
If you're only fixing the sag, you don't need to do anything to the torsion bars.
With regards to fixing the sag, new leafs is the best way. Blocks will raise the back up but with sagging springs you are VERY close to the bump stops so would have very little travel and would have a rough ride.
And I recommend replacing the u-bolts if you replace the springs, though it's not totally necessary. Just something to consider.
Old Feb 1, 2009 | 03:20 PM
Joby8103's Avatar
well i just wanted to fix sag but got to thinking if i did three inch springs I could get torsion bars and crank them a little?
Old Feb 1, 2009 | 03:27 PM
Three inches is A LOT to expect from torsion bars... even if you did 2" BJ spacers. You would be stressing the front CV's at such angles.
Search the forums about torsion bar crank and t-bar lift and... well just about any other way to rephrase it.
Old Feb 1, 2009 | 05:31 PM
Joby8103's Avatar
ugh..the more i search the more my head hurts! lol...there is just to many options and to much to know!
Old Feb 1, 2009 | 06:42 PM
everything in moderation.
Old Feb 1, 2009 | 08:45 PM
annoyingrob's Avatar
I just stuck some coil springs on top of my leaf springs. Fixed my sag
Total cost, free becasue I had the springs layig around.
Old Feb 1, 2009 | 08:51 PM
4Crawler's Avatar
Some pros and cons of various lift options discussed below:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ14
With stock height replacement springs, what else needs to be replaced depends on your luck removing the old springs. If everything comes apart without damage, you can usually re-use all the parts (spring hanger bolt, u-bolts, shackles, etc.), but if any of those parts needs to be cut off, you'll need to replace them.
Old Feb 1, 2009 | 09:49 PM
BLKNBLU's Avatar
I would also suggest new springs. You will spend in the neighborhood of $100 on new shackles unless you can make them yourself. For about $225 you can have new springs that will work very well. I had the Downeys until my SA and they were fine. They are now providing service under a second runner. If money is super tight go ahead with the shackles. Just keep in mind you will probably end up getting springs somewhere down the road. Remember the old saying:
Not enough time/money to do it right, but always enough time/money to do it twice.
Old Feb 1, 2009 | 09:51 PM
hey blknblu, so if i put the load carrying leafs on mine, itll lift it up just a bit right?
Old Feb 1, 2009 | 10:31 PM
BLKNBLU's Avatar
Not sure I'm following you. I'll PM you and we can hash it out. If any of it is useful, we can come back here and post it up for everyone.
Old Feb 2, 2009 | 09:57 AM
Joby8103's Avatar
ok thanks guys! so what about shocks?
Old Feb 2, 2009 | 10:30 AM
BLKNBLU's Avatar
Once you install whatever fix you decide on, check compression and extension measurements on each side with no shocks on. Your shocks will need to be a touch shorter compressed than your shortest measurement. Otherwise your shocks become your bumpstops which will mean a short lifespan for your shocks. Try to get as close to those measurements as you can while making sure you keep a compressed shock measurement shorter than your compressed truck measurement. (i.e. if your axle to frame measurement is 15 inches compressed make sure your shock measurement is less than 15 inches compressed) You can throw your current ones back on without any problem while you shop for a deal. They will likely be shorter than the optimal size but won't hurt anything. It will just cost you a bit of droop. If your asking about brand recommendations, you will find as many opinions as there are members here, so good luck.
Blamalam
Mar 12, 2022 07:34 AM
icentropy
Sep 16, 2020 02:47 PM
cars-guy
Aug 16, 2020 06:59 AM
jasonty
41
Dec 23, 2018 01:00 PM
Numberonedad6
Jul 30, 2015 07:10 PM
