Slip Yoke Compatibility
I'm replacing a bad front U-joint on the rear driveshaft of my 86 4X4 pickup and I noticed that one of the holes on the slip yoke is worn. (Stub shaft, whatever it's called) Before I head to the junk yard to search for a replacement, I'd like to know what years and models I should be looking for. Thanks!
Year isn't as big a factor as 4x4 or 2x4, auto or manual, v6 or 4 cyl. I doubt they will sell you just a slip yoke. You will probably have to get the whole drive shaft. Make sure you factor in getting it balanced and phased as the places I got mine from didn't even feel that taking out the slip yoke and putting it back in where ever was that big of a deal, but it can make some vibrations still that will wear out your u-joints. As for matching it up, i would take some handy photos with you of your existing one as the flanges and a couple other things change in appearance to what won't work.
Thanks for replying. I hope to get lucky and find one at a Pick-n-Pull, where I'd just be able to buy a slip yoke alone....but I'm not holding my breath! If a yard will only sell me the entire drive shaft, maybe I'd just be better off getting a new slip yoke from the local driveline shop and having them balance the whole thing at the same time. I'll compare prices and get it figured out.
kawazx636
Oct 6, 2021 03:03 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
