Sliding rear cab window?
Old Feb 24, 2007 | 04:46 PM
curtiswyant's Avatar
I just got a camper shell for my '87 pickup, is there any easy way to put a sliding rear window in the cab so I could reach into the bed?
Old Feb 24, 2007 | 05:05 PM
Just Learning's Avatar
well you most likely have to get a sliding rear window, or you could do the "custom way" punch a hole through your back window
Old Feb 24, 2007 | 05:15 PM
CanTheWhales's Avatar
It's a straight swap out of an SR5 model within the same generation...I'm gonna put one in mine someday (probably after I break the old one)
Old Feb 24, 2007 | 06:10 PM
dh515's Avatar
Check Ebay. I got one for my 88 for about $60 delivered from east to west coast. New, I've seen them for about $120. CR Lawrence is the company that made mine.
Old Feb 24, 2007 | 10:11 PM
SwampThing's Avatar
Well, if you're a do-it-yourself'er, and don't mind a little bit of redneck-ism, here's what yer gonna wanna do. Swing on by home depot or lowes and pick yerself up some 24"x48" plexiglass, either rubber cement or sealant, 2 wooden window shutter hinges, and a door latch. 1/4" thick plexi is fine, but 3/8" sits a little snugger. Make yerself a template of the shape of the window with some cardboard and make where you are going to split the plexi into three pieces. Once ya have done that, go ahead and make your cuts. Rubber cement the two outside window cuts into the window cavity. Then prop up the inner window where you need it to be, mark your holes for drilling the starter holes for the latch and hinges, drill em, install hardware, and vola. You got yerself a nice beer window now! I've done this to about 5 trucks now, and it's worked great. Here's a little pic to give ya a little better idea.
Old Feb 25, 2007 | 07:57 AM
KLF's Avatar
KLF
Holy crap... redneck is right.
I've got a nice factory OEM rear sliding window out in my garage that I'll sell cheap, say $30. Came out of an '87 reg cab truck. Won't fit an xcab, BTW. Includes the cab gasket. Very easy to swap, only takes a few minutes.
Old Feb 25, 2007 | 08:39 AM
GV27's Avatar
LOL, a Redneck tip from SwampThing? Say it ain't so!
Old Feb 25, 2007 | 01:51 PM
I'll take it....seriously, sending PM now
Old Feb 25, 2007 | 08:33 PM
little bit of redneck-ism, ha ha
Old Feb 25, 2007 | 08:42 PM
frodin1's Avatar
If your putting one in. Get some clothesline rope put in the track of the gasket have someone outside push "not hard or you'll tear the gasket", while someone inside pulls the line and gradually rolls the gasket back .Work your way around and you'll be done. Takes 5 minutes. Taking one out just work the gasket until its popping out then have a friend pull while you push! Good luck!
Old Feb 25, 2007 | 11:13 PM
SwampThing's Avatar
Well, if ya caint think of a word to say what ya mean, make one up! But ya know yer a redneck when yer truck is held together with more bailing wire, zip ties, duct tape, gorilla glue, and sheet metal screws than any single hardware store supplies at a given time. But hey, those aint dents, they're battle scars. And it aint beat up, it just has character!
Old Feb 25, 2007 | 11:37 PM
DeathCougar's Avatar
use some Soapy water too. Really helps.
Old Feb 26, 2007 | 10:36 AM
surf4runner's Avatar
use bar soap on the rope. (so you dont drop it )
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
cyclist231
Jul 7, 2015 12:56 PM
Nickdigg
Jul 7, 2015 06:04 AM
coryc85
Jul 6, 2015 04:07 AM
