On the side of the road again
Old Apr 13, 2021 | 05:53 PM
  #41
RAD4Runner's Avatar
Originally Posted by superex87
Here is a link with pictures to further explain.
Injector wiring link
Originally Posted by Jef Free
The resister or solinoid has 2 to 3 for resistance and there is continuity from injector plugs to wires at ecu
i think that tells me that wiring is good and should be getting signal if one is being sent.
Need to check continuity of EACH injector negative to BOTH pins 10 and 20 of ECU.
Old Apr 13, 2021 | 08:30 PM
  #42
Jef Free's Avatar
Identify that serindipious
that’s what I was planning on doing next as soon as rain lets up
i checked air gap at signal coil spot on.
I have continuity from the distributor wires in the igniter to ecu.
i had high resistance on the signal coil in the distribution and I also checked all 4 wires from tps to ecu and they all had continuity and their resistance as far as I understand it were good..I have given the tos more thought and even though it was not connected and looked like the culprit it could of and most likely did fall off many miles before the stall because the zip tie holding it was broken and I had simply not gotten to the repair yet. I recall i she was breaking up many miles prior and I certain it was a plug wire that I had 10 miles before replaced all of them because she was running on three cylinders at least that is how she was acting . The resistor checks out fine but for some reason I suspect it. I have a date and will probably throw that on at some point. I have recently soldered and shrink wrapped them and hate to open them up😉
from what I have read the ne signal rarely fails but it could be. What about the other signal the g* and igt
thanks
Old Apr 15, 2021 | 06:05 PM
  #43
Jef Free's Avatar
On again off again
Scratching my head until I had a line of rabbits walking backwards on my head (receding hare line)I decided to check spark again. Being I was alone turning the key and holding the plug to ground was a yoga move and after checking again and thinking that the weak spark was due to it being a poor ground I decided to throw on a spare coil I had. Bingo fired right up. 7 days, at least 3 new lifelong friends a free battery and countless hours busking on the streets of eureka and much more I was on the road again. At least until that evening when I went to leave an open jam my battery was to weak to support headlights cause alternator was not charging. So all the connections and grounds that I had cleaned were all looked at again., voltmeter test and this one o puzzles me. Why with ign on do I get 12 volts to each side of fusible link. I think it’s the 8 week old alternator regulator cause all else checks out. Charge light was on that entire day so it was not a surprise but what gets me is when I broke down a week ago my dash volt meter read 14 and now 12
any input?
Another note worth mentioning is # 1 injectors lead has a intermittent miss rectified with a wiggle so I think perhaps that was is part of my problem. I know now the location of all grounds and all my connections are clean with a dab of dialect ric paste so that’sa good thing
thanks everyone from this imposter mechanic.
I’ll get to advice on my proportional valve next time
Old Apr 16, 2021 | 08:01 AM
  #44
87-4runner's Avatar
Well, thank God you finally got it figured out. Glad you made some new friends. Hope your travels after getting the alternator issue rectified will be a blessed adventure full of wonderful experiences.
seems you made lemonade out of the lemons you were given.
Old Apr 22, 2021 | 03:37 PM
  #45
Dernation's Avatar
Thank you so much for keeping with it, keeping us updated, and posting your solution!
swampedout
May 27, 2019 06:17 AM
92yoterDD
Aug 23, 2014 10:09 PM
JPL
Jan 2, 2013 04:01 PM
affmondo22
Sep 11, 2009 07:31 PM
weakyota91
Jan 28, 2008 10:20 PM
