Which side of the caliper moves?
I have an 86 Runner that has a sticking front right brake caliper. Noticed that only the pistons on the outermost side are compressible. I would have thought the pistons on both sides would travel when pressure builds up in the caliper cylinders. Anyone know if the inner side pistons should expand/contract? I would have thought the pistons pushed from both sides since the caliper itself is bolted directly to the hub and would otherwise warp the rotor.
Aaron
Aaron
You are correct. All four pistons should move freely. You can take the caliper apart to rebuild it with a new seal kit, but if some of your pistons are sticking, you will likely find that those pistons have corrosion pitting on them, which means you'll need to buy replacement pistons also. Depending on how many pistons you need, you may be able to buy new remaned calipers for similar price (although I'm sure in the US, you guys can get pistons for $10-$15 a piece... up here, they were over $30 canadian each).
YAY!!!
On our trucks the caliper is mounted and the pistons float. Many vehicles have only one set of pistons (or even one piston) and the caliper slides (a.k.a. "floating caliper") to bring the outer pad in to the disc.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
